Custom Toggle Switch on Ribbon?
I am wondering if there is a way to have a command button on the ribbon that will toggle on and off certain layers.  Additionally, I would like the ICON of the button to swap from one image to another depending on which state the toggle is in.  Is anything like this possible?
rkmcswain
For the first part, are you using AutoCAD or AutoCAD LT?
Also, you say layer"s". So I presume you want to turn them all off (or freeze) and then do the reverse?
What if their current state is some off and some on? Reverse that state or flat out turn them all off, then all on at the next toggle?
I am using AutoCAD Mechanical 2019.  I have some notes that are on a layer named "CKNOTES" and I need a way to toggle the layer on and off.  I don't think that's going to be the issue.  What I'm really wondering about is how I can visually represent on the ribbon if the layer is on or off depending on the layer state.
rkmcswain
You used to be able to (and perhaps still can) place a checkmark next to a pull-down menu item using a menu macro, but I don't know about swapping images on a ribbon item.
Perhaps it can be done with something other than a menu macro or autolisp.
