modify dimension text from base point to selected point
modify dimension text from base point to selected point. Its not work with entmod and entupd functions.
Kent1Cooper
I can't explain why the (entmod (subst ...)) approach doesn't work, but I find in minimal testing that VLA Properties  can be used to do it:
(vlax-put DimensionAsVLAObject 'textposition YourNewPointCoordinatesList)
Kent Cooper, AIA
john.uhden
Maybe you aren't using the proper DXF code.  I know that I have used entmod to modify dimension entities.
I suggest that you create a dimension, copy it in place, relocate the text, and compare the two (entget)s for differences
Here's a little helper...
(defun c:Entget ( / e)
  (if (setq e (car (entsel "\nSelect object to list entity data: ")))
    (print (entget e))
  (princ)
or, if you want to see one dxf code per line, then...
    (mapcar 'print (entget e))
  (princ)
John F. Uhden
I am putting proper value in dxf code 11 which is text position.
Thanks its Working properly for me
thanks for reply sir
dbhunia
Another approach.......
(vlax-put-property DimensionAsVLAObject 'textposition ActiveX-compatible (variant) 3D point structure)
(vlax-put-property (vlax-ename->vla-object (car(entsel "\nSelect Dimension: "))) 'textposition (vlax-3d-point (getpoint "\nPick Text position: ")))
@Anonymous  you wrote "I am putting proper value in dxf code 11 which is text position."
It works only for "Linear" Dimension for other Dimensions you have to control dxf code 10 also......
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
