custom commands in cui file to Excel
CADmgrMike
CADmgrMike
I have a custom cuix file we've used for years and I would like to capture it in Excel so we have a visual way to manage changes going forward.
Is there a way to get any of the custom commands into Excel besides copy/pasting the name and command.
Mike Porter
https://provostandpritchard.com/
Sea-Haven
So you don't have the mnu version ? You can get at the cuix and look inside but its a bit of a mess to pull it a part. Make a copy of the cuix then rename to .zip, then you can look inside at all the xml files. Its still a bit of work to edit back to a mnu style text file.
So this dr_pav_bend in a image section of a mnu
paullimapa
I typically do screen captures and place into Word to explain the steps for customization. Is there a reason you prefer to do this in Excel?
Paul Li
IT Specialist
@The Office
CADmgrMike
@paullimapa,
I like Excel for the row/column organization.
I will do screenshots of the actual custom menus.
I just wanted to capture the custom commands in a format where I can visualize inconsistencies in naming, etc.
And I can create new similar commands by copy/pasting the macro from Excel to the new command.
Saves from having to scroll through the list inside the cuix file and find a similar command.
This is for management/organization than anything useful for a typical CAD user.
Mike Porter
Sea-Haven
If you do as I suggested and go back to a Custom.mnu then you have access to it in Notepad or Word etc.
***MENUGROUP=ALANSTOOLBAR
***TOOLBARS
**ALANSTOOLS
ID_ALAN_0    [_Toolbar("Alans1", _Right, _Show, 0, 0, 1)]
AECC_ShowTS  [_Button("Show Toolspace", RCDATA_16_IMAGE, RCDATA_16_IMAGE)]^C^C^C^P_ShowTS
ID_Matchprop [_Button("Match Properties", RCDATA_16_MATCH, RCDATA_16_MATCH)]^C^C_matchprop
ID_Erase     [_Button("Erase", RCDATA_16_ERASE, RCDATA_32_ERASE)]^C^C_erase
ID_Copy      [_Button("Copy", RCDATA_16_COPYOB, RCDATA_32_COPYOB)]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_copy,^C^C_copy)
ID_Mirror    [_Button("Mirror", RCDATA_16_MIRROR, RCDATA_32_MIRROR)]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_mirror,^C^C_mirror)
ID_Offset    [_Button("Offset", RCDATA_16_OFFSET, RCDATA_32_OFFSET)]^C^C_offset
You can see what is being used. The hard bit you can copy from the cui to a mnu file just takes a bit of time, like wise can copy from the cui the icons etc. There is no ribbon mnu unfortunately.
CADmgrMike
I found an old thread about converting a cuix file to mnu that had a program to convert. Haven't tried it yet.
I can see where the mnu would be a way to see everything in a more logical way.
Mike Porter
Sea-Haven
CUI to MNU.vlx ? It converts CUI not CUIX. Make a copy of your cuix then rename it to a ZIP file and extract all the CUI, you can look inside then try the CUI to MNU.
