lisp for creating drawings layout list table stopped working
monzoor.hossain
monzoor.hossain
Hi i have this lisp for creating drawings layout list table, it was working but all of a sudden it gives error mgs: "error: ADS request error",
if one out their can help me to solve this issue, will be highly appreciated,
My template & related script attached
[ The subject line of this post has been edited for clarity by @pendean Original: Cad Administrator]
Monzoor
paullimapa
There are two sections I changed to make the routine run successfully:
Section 1 - Commented out lines causing errors & replaced with new code:
  ;; Get attributes/vals from title blocks
; add this to initialize i value
  (setq i 0)
  (foreach lay (cdr (layoutlistordered)) ; this skips first layout tab
    (if (setq ss (ssget "_X" (list (cons 0 "INSERT") (cons 2 "CBC-TITLE_A3LAYOUT") (cons 410 lay))))
	  ;; sheetInfo = (layoutName description issue)
	  (setq e (ssname ss 0)
            sheetInfo
			  (cons
			    (list
				  lay
				  (strcat
					(getpropertyvalue e "SHEET-DETAILS")
; add space
;					(getpropertyvalue e "1") ; this does not exist
;					(getpropertyvalue e "SHEET-NUMBER-OF-X1") ; for some reason this is always set to 1
; add this to get page #
          (itoa (setq i (1+ i)))
					" OF "
;					(getpropertyvalue e "2") ; this does not exist
;					(getpropertyvalue e "SHEET-NUMBER-OF-X2") ; for some reason this is always set to 1
; add this to get total pages not including first layout
          (itoa (1- (length (cdr (layoutlistordered)))))
				  );strcat
				  (getpropertyvalue e "ISSUE")
				);list
				sheetInfo
			  );cons
	  );setq
	);if
	(setq ss nil)
  );foreach
Section 2 - Commented out the following 3 lines of code:
;  (vla-SetTextStyle t_Style2 acTitleRow "ARIAL")
;  (vla-SetTextStyle t_Style2 acHeaderRow "ARIAL")
;  (vla-SetTextStyle t_Style2 acDataRow "ARIAL")
See attached revised files
Paul Li
IT Specialist
@The Office
monzoor.hossain
Hi Paul,
Thank you so much for your kind help, this is why i always reach out to this forum whenever i am in need of help,
i have gone through your correction & this will help me to correct my other scripts for which i forever grateful to you.
Thanks again,
Monzoor, from Sydney Australia
paullimapa
Glad to have helped…cheers from Los Angeles, California USA
Paul Li
IT Specialist
@The Office
