Here you have it. Works only with polylines (plines).
(defun c:wire_jumper( / LM:intersections pick_poly take take2 pointlist2d pl plo pt cir co intlist di tmp ang coords i radius);
;Author: hak_vz
; Monday, September 6, 2021
;https://forums.autodesk.com/t5/user/viewprofilepage/user-id/5530556
;Posted at
;https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/crossing-two-lines-with-arc/td-p/10602471
;Creates arced wire jumper at intersection between two wires
(defun LM:intersections ( ob1 ob2 mod / lst rtn )
(if (and (vlax-method-applicable-p ob1 'intersectwith)
(vlax-method-applicable-p ob2 'intersectwith)
(setq lst (vlax-invoke ob1 'intersectwith ob2 mod))
(repeat (/ (length lst) 3)
(setq rtn (cons (list (car lst) (cadr lst) (caddr lst)) rtn)
lst (cdddr lst)
(reverse rtn)
(defun pick_poly ()
(setq e (car(entsel "\nSelect polyline >")))
(if (and (not e) (= (getvar 'Errno) 7)) (pick_poly) e)
(setq radius 2); change this according to your preference
(defun take (amount lst / ret)(repeat amount (setq ret (cons (car lst) (take (1- amount) (cdr lst))))))
(defun take2 (lst) (take 2 lst))
(defun pointlist2d (lst / ret) (while lst (setq ret (cons (take 2 lst) ret) lst (cddr lst))) (reverse ret))
(setq pl (pick_poly))
(setq plo (vlax-ename->vla-object pl))
(setq pt (vlax-curve-getclosestpointto pl (getpoint "\nSelect wire jumper intersection point >")))
(setq cir(entmakex (list (cons 0 "CIRCLE") (cons 10 pt) (cons 40 radius))))
(setq co (vlax-ename->vla-object cir))
(setq intlist (mapcar 'take2 (LM:intersections co plo acextendboth)))
(setq coords (append (pointlist2d(vlax-get plo 'Coordinates)) intlist))
(vlax-release-object co)
(entdel cir)
(foreach c coords
(setq di (vlax-curve-getDistAtPoint plo c))
(setq tmp (cons (append (list di) c) tmp))
(setq coords (mapcar 'cdr (vl-sort tmp '(lambda (x y) (< (car x)(car y))))))
(vlax-put plo 'Coordinates (apply 'append coords))
(setq coords (pointlist2d(vlax-get plo 'Coordinates)))
(setq test T i -1)
(setq intlist (vl-sort intlist (lambda (x y) (< (vlax-curve-getDistAtPoint plo x) (vlax-curve-getDistAtPoint plo y)))))
(while test
(setq i (1+ i))
(if (= (distance (nth i coords) (car intlist)) 0.0) (setq test nil))
(setq ang (+ (angle (car intlist)(cadr intlist)) (/ pi 2.0)))
(setq pt (take2 (polar pt ang radius)))
(cond
((or
(< (angle (car intlist) (cadr intlist)) (/ PI 2))
(> (angle (car intlist) (cadr intlist)) (* 1.5 PI))
(vla-SetBulge plo i -1.0)
(T (vla-SetBulge plo i 1.0) )
(princ)
Change arc radius value according to your preference.
Since you are new member to this forum, if this solves your request, accept this as a solution (green button Accept).
Miljenko Hatlak
