Crosshair visible in Splittscreen
Hello, everyone
Is there a setting for Autocad in which you can set the visibility of the crosshairs so that you can see them in 2 viewports at the same time?
Example:
In picture 1, the trees are aligned as they should be.
Picture 2 shows the floor plan where I have to move the trees.
Instead of putting an XLINE on every tree, it would be easier if you could see my Y-axis from the crosshairs in teh other viewport.
I hope someone can help me with this.
thanks
john.uhden
I never work with TILEMODE=1, so I can't tell you.
But maybe a workaround is to include a vertical no-plot xline in each tree block definition so it shows at your viewport's border to help you eyeball the placement better.  Since they are just trees and not bolt holes I would think that being close enough is good enough.
John F. Uhden
