Area for all Hatches & Polylines and divide it
Dears
I have got by helping from mr @ВeekeeCZ  lisp to calculate area for polylines one time and divided all result by 9.1 or other no. (Lisp attached), this lisp working with polylines only (all polylines one select), I need it to work with Hatches also from same matter in same lisp if we can.
john.uhden
Be careful.
I do a lot of area analyses.  Just in the last two years I found hatches to be handier because you can hatch around islands and the hatch area excludes the "holes."  And hatches are easy to select.  But I have run into a number of hatches that have no area.  I think it's when they touch themselves.  So, please be sure each one has an Area property before you blindly add them up and divide.
Perhaps @Z9E3zK5E (mr is a ms) could add a check and warn you if there is one or more of those in your selection set.
I need to remember to add that to my own ADDAREAS program.  Whole square feet is good enough for my analyses, so just grip-stretching the troublesome vertex a fraction doesn't change the area very much.
John F. Uhden
Thank you, any time I use lisp I make check and check to be sure everything working properly, anyway thanks for your note.
ВeekeeCZ
Try this one. I did not add any no-area hatches... The best approach would be to pre-select hatches, check whether is Cumulated area calculated, run the routine, fill up the prompts, then type "p" to apply the previous selection.
Grate 🌻 It's working, but ...
1-not all hatches one time, by any selection method.
2-for hatches with arcs and polylines give me result very far that will make confuse.
3- If you can make same lisp working for polyline and hatch in same time it will be great.
Sample attached.
Sea-Haven
`Being a civil designer and the dwg is obviously a road is the hatch meant to be kerbs and concrete infill or is the narrower section a concrete kerb edge ? If its not a road just disregard.
