Promt keywords in ENTSEL
Browning_Zed
Message 1 of 23
Browning_Zed
Hi All,
Help me please. I cannot understand how keywords work in promt. I need to execute the ENTSEL function using keywords.
First, I put keywords in INITGET:
(initget "Type Form")
Then I need to execute the ENTSEL function:
(entsel "\nPick: [Type/Form]")
During the execution of the ENTSEL function, before the entity is picked, I can select keywords [Type/Form].
After that, I need to return two variables with set values:
1. Entsel value of the picked entity in one variable.
2. The value of the keyword: "Type" or "Form" in another variable.
How can i do this?
Replies (22)
Message 2 of 23
ВeekeeCZ
Unless you don't want to have two prompts, you need to have one with a default option the will be applied if the user just pass the prompt.
(defun c:Test ( / ent tmp)
  (or *option*
      (setq *option* "Type"))
  (while (not ent)
    (princ "\nCurrent setting: ") (princ *option*)
    (setq tmp (entsel (strcat "\nPick or [Type/Form] <" (if (= *option* "Type") "Form" "Type") ">: ")))
    (cond ((not tmp)    (setq *option* (if (= *option* "Type") "Form" "Type")))
	  ((listp tmp)	(setq ent (car tmp)))
	  (T 		(setq *option* tmp))))
  (list ent *option*))
Message 3 of 23
Browning_Zed
Thank you, this is what I need!
I'm also wondering what the code will be if there are more than two keywords, for example:
[Type/Form/Item/Build]
Message 4 of 23
ВeekeeCZ
  (or *option*
  (while (not ent)
    (initget 1 "Type Form Item Build")
    (princ (strcat "\nCurrent setting: " *option*))
    (setq tmp (entsel "\nSelect entity or pick [Type/Form/Item/Build]: "))
    (if (listp tmp)
Message 5 of 23
Browning_Zed
Thanks for the help.
Message 6 of 23
ВeekeeCZ
Do you understand the code or do you need to add some comments?
Message 7 of 23
Browning_Zed
Thank you, the code is clear. One question: *option* variable set as global just to remember the last state of the keyword? Or is the global status of this variable needed for something else?
Message 8 of 23
ВeekeeCZ
Yes, just to remember the last one. Make it local if you want to have the default option always the same.
Message 9 of 23
Browning_Zed
Thanks!
Message 10 of 23
Browning_Zed
Can you help me a little more?
What if, when I select one of the options, I don't need to set it to a variable, but just run a specific action. I will explain:
(or *option* (setq *option* "Type")) ; set variable *option* to "Type"
(setq tmp (entsel "\nSelect entity or pick [Type/Form/Delete]: "))
here if selecting "Form", then this will set the variable *option* to "Form". But if selecting "Delete", then execute expression (entdel (entlast)), and leave the variable *option* with the same status, that is, do not change the value of this variable. The loop is not interrupted during the execution (entdel (entlast)).
Message 11 of 23
ВeekeeCZ
Then get back to the cond func and add one more condition... do you understand how cond works and where and why to put it?
Message 12 of 23
Browning_Zed
I understand how the cond works, but I do not understand how it can be put into this code.
Message 13 of 23
ВeekeeCZ
Then tell me, how does the cond work?
  (or *option*
  (while (not ent)
    (initget 1 " Type Form Delete")
    (setq tmp (entsel (strcat "\nPick or [Type/Form/Delete]: ")))
    (cond ((listp tmp)		(setq ent (car tmp)))
	  ((= tmp "Delete")	(entdel (entlast)))
Message 14 of 23
Browning_Zed
Thank you so much! Now I understand.
Message 15 of 23
ВeekeeCZ
Ok, good. Just tell me why it could not be the last condition.
Message 16 of 23
Browning_Zed
Because the last condition is to exit the loop?
Message 17 of 23
ВeekeeCZ
As matter of fact, in this case, is the first one responsible for exit if is true.
Message 18 of 23
Browning_Zed
Yes it is. Then I don't understand what T means in the expression (T (setq * option * tmp))
Message 19 of 23
ВeekeeCZ
Here is something to help you understand the cond.
; universally
(cond (test1		result1)
      (test2 		result2)
      (test3 		result3)
      (test4)
      (test5 		result5)
(cond ((= tmp "Delete")       	(princ "It's Delete!")) 			; if tmp is "Delete",  test1 is T and result1 is taken and OVER - the cond returns the value if result1 (prints "It's Delete!"). Other conditions (like test2) are not even tested!
      (tmp 			(princ "It's something else than Delete!"))     ; if tmp is some value (its not nothing but neither "Delete". Because if it was "Delete", it would have already been taken.). so if tmp was "Item", the cond returns "It's something else than Delete!" and over.
      ((and tmp T) 		(princ "I do understand the cond!"))		; can cond, in this example, ever return this line?
      ((not tmp))		   						; if there is no result, the cond returns value of test itself! So when this line will be taken and what the result would be?
      (T 			(princ "Nothing is True"))			; T as True is test5 expression. But it's always True.... if non of previous tests were is taken. Can cond, in this case, ever return this line?
Message 20 of 23
ВeekeeCZ
*option* is one word! No spaces. Btw asterisks are just letters with no special functionality. Just convention.
it could also be +option+ for example... or goptiong It would work the same.
