Creating installation file for a plugin
Shay.Gaghe
Shay.Gaghe
Hi
I hope this the right board to ask this.  My company developing an autocad plugin , by lisps and used by costumized suppoautomatedrt files.
We want to create an install.exe for out plugin and of what i have in mind by now is the folowing:
1. Paste supporting files to C:\Users\user\AppData\Roaming\Autodesk\ApplicationPlugins\
2. paste profile.aws folder to C:\Users\user\AppData\Roaming\Autodesk\ACA 2019\enu\Support\Profiles\
3. paste toolpalette folder to C:\Users\user\AppData\Roaming\Autodesk\ACA 2019\enu\Support\ToolPalette\Palettes
4. paste cuix to
C:\Users\user\AppData\Roaming\Autodesk\ACA 2019\enu\Support 5. past switched shortcut to desktop
Am i missing something?
SHAY
Using Autocad 2018, Autocad Architecture.
Please accept as solution if i solved your problem
scot-65
One should use a directory structure that is isolated from the
AutoCAD OOTB directory structure.
Exception: Creating a sub-directory in the "Bundles" directory
for bundle apps.
Suggest:
Stick with Program Files for "common" items for all users and
AppData/Roaming area for user-specific items (acad.pgp).
<the program files area can also be interpreted as server area>
Why? New AutoCAD installs and/or updated AutoCAD software
will be easier to execute your custom menu system loading.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
_Tharwat
Why don't you hire someone to create installers for your plug-ins ? 😉
cadomatic
how to quote here?
Sea-Haven
I put all my customer supplied package in a known directory, I just get them to unzip to this directory, a lisp can then be run that does all the menu stuff, paths etc.
I am going to look at self extracting zip so it will make all the correct directories.
