creating a new/open/save/close lisp
Satoews
Message 1 of 12
Satoews
I have been trying to figure out how to creat a lisp that would let me
  1. Type in a file number
  2. if the file is in the a certain folder it would open it
  3. if not it would create a new file in the before mentioned folder.
  4. it would then save and close the previous file i have been working on.
  5. If it could also lastly end in editing an attribute for the new drawing that would be great, epic block lot is the block name.
I currently have it set to print to pdf when it saves the file, i don't think that would be effected but i wanted to throw that out there as well.
Any help or direction in where to start is greatly appriciated.
Thanks in advance
Shawn T
Replies (11)
Message 2 of 12
hmsilva
Hi shawnt,
what occurs to me is to use a '.scr' file to close/open, to the rest of the code we can use Auto/VisualLISP.
"epic block lot" is the block name?
If so, what is the TAG?
Henrique
Message 3 of 12
Satoews
I have three tags for Epic Block Lot
ADD
ST1
CTY
thanks!!
Shawn T
Message 4 of 12
hmsilva
ADD
ST1
CTY
thanks!!
One more question, is the block in model, or in layout?
Henrique
Message 5 of 12
Satoews
It is in a layout, LOT-HOUSE if you need the name.
thanks!
Shawn T
Message 6 of 12
hmsilva
thanks!
shawnt,
as a starting point
(defun c:demo (/ *error* dwgname name new newfile ofile scrfile)
   (defun *error* (msg)
      (if ofile
         (close ofile)
      (cond ((not msg))
            ((member msg '("Function cancelled" "quit / exit abort")))
            ((princ (strcat "\n** Error: " msg " ** ")))
      (princ)
   (if (and (progn
               (initget 6)
               (setq new (getint "\nEnter the next dwg number: "))
            (setq name (strcat (itoa new) ".dwg"))
            (setq dwgname (strcat (getvar 'dwgprefix) name))
      (progn
         (if (vl-directory-files (getvar 'dwgprefix) name)
            (setq newfile (vla-open (vla-get-Documents (vlax-get-acad-object)) dwgname :vlax-false))
            (setq newfile (vla-add (vla-get-documents (vlax-get-acad-object)) (getenv "LastTemplate")))
         (vlax-for layt (vla-get-layouts newfile)
            (if (= (vla-get-name layt) "LOT-HOUSE")
               (vlax-for blk (vla-get-block layt)
                  (if (and (= (vla-get-objectname blk) "AcDbBlockReference")
                           (= (vla-get-effectivename blk) "Epic Block Lot")
                     (foreach att (vlax-invoke blk 'getattributes)
                        (cond ((= (vla-get-tagstring att) "ADD")
                               (vla-put-textstring att "New address...")
                              ((= (vla-get-tagstring att) "ST1")
                               (vla-put-textstring att "New state...")
                              ((= (vla-get-tagstring att) "CTY")
                               (vla-put-textstring att "New city...")
         (vla-saveas newfile (strcat (getvar 'dwgprefix) name))
         (vla-close newfile)
         (setq scrfile (strcat (getenv "Temp") "\\My_Open.scr")
               ofile   (open scrfile "w")
         (write-line "_.qsave" ofile)
         (write-line "_.close" ofile)
         (write-line "_.open" ofile)
         (write-line (strcat "\"" dwgname "\"") ofile)
         (close ofile)
         (command "_.script" scrfile)
Hope this helps,
Henrique
Message 7 of 12
Satoews
appologies for the late response, few issues:
  • only seems to accept 5 digits for the file number
  • the block needs to be edited every time, any way to just automaticly open enhanced attribute editor?
  • the previous drawing dosen't seem to close on its own.
I am learning a lot from your lisp thru the autodesk help and trying to figure out what this is doing.
thanks again!
Shawn T
Message 8 of 12
hmsilva
thanks again!
Hi shawnt,
the 'demo' it was just a starting point, for your code...
I did change the function to get the 'numbers' for the new dwg, to allow a large number of digits.
The 'demo' show a way to change the attributes in the new dwg without the need to open enhanced attribute editor, if your goal is to use the values from 'Epic Block Lot' at the current dwg, and copy to yhe new dwg, it's easy to add that feature in the code.
the previous drawing should close...
I added some comments to the code...
;; error function
       ; if the ofile is open during the error, close it
      (if ofile
         (close ofile)
      (cond ((not msg))
      (princ)
    ;; main program
    ; asks the user to enter a new number (as a string to allow a large number of digits)
   (if (and (setq new (getstring "\nEnter the next dwg number: "))
            ; test if not an empty string
            (/= new "")
             ; test if the user did enter a valid dwg name
            (snvalid new)
            ; set name with file extension
            (setq name (strcat new ".dwg"))
            ; set dwgname with full path
       ; if all previous functions are true:
      (progn
          ; test if dwg exists
             ; if exists, open it and set newfile with it, as a vla-object
             ; if not exists, add it to the document collection using the lat used template, and set newfile with it, as a vla-object
         ; foreach layout (layt) from layouts collection from newfile
             ; test if layout name is "LOT-HOUSE"
                ; if true, forech block from block collection
                   ; test if is objectname property from blk is a "AcDbBlockReference"
                           ; and test if the effectivename property from blk is "Epic Block Lot"
                      ; if the previous tests are true
                      ; foreach attribute
                         ; if tagstring is:
                               ; put "New address..."
                               ; put "New state..."
                               "New city..."
         ; save the newfile
         ; close the newfile
         (vla-close newfile)
         ; start to create the script file
               ; open the script file to write "W"
         ; write at ofile:
         ; qsave
         ; close
         ; open
         ; the dwg name to open
         ; close the ofile
         (close ofile)
         ; call the script command to run the previous cript file
Hope this helps,
Henrique
Message 9 of 12
Satoews
VERY NICE, THANK YOU FOR THE EXPLANATIONS IN THE LISP!
THANKS!
Shawn T
Message 10 of 12
hmsilva
THANKS!
You're welcome, shawnt
Glad I could help
Henrique
Message 11 of 12
Satoews
Sorry to bug you again with this one but I am stuck on one thing that is driving me nuts.
Changes to the code:
  • I added T to the getstring so it can accept spaces.
  • added getstrings to the attributes so I can edit them on the fly.
I am stuck on:
In the beginning of this code I need to be able to print the previous file. I can't figure out how to add in code right to not break the lisp.
Thanks in advance.
(defun c:demo (/ *error* dwgname name new newfile ofile scrfile ADD0 ST0 CTY0)
;; error function
      (if ofile
         (close ofile)
      (cond ((not msg))
      (princ)
    ;; main program
   (if (and (setq new (getstring T "\nEnter the next dwg number: "))
            (/= new "")
            (snvalid new)
      (progn
                      ; foreach attribute
                         ; if tagstring is:
                               (SETQ ADD0 (GETSTRING T "\nEnter the Address Number: " ))
                               (vla-put-textstring att ADD0)
                               ; put "New street..."
                               (SETQ ST0 (GETSTRING T "\nEnter the Street Address: " ))
                               (vla-put-textstring att ST0)
                               ; put "New city..."
                               (SETQ CTY0 (GETSTRING T "\nEnter the City: " ))
                               (vla-put-textstring att CTY0)
         ; save the newfile
         ; close the newfile
         (vla-close newfile)
         ; write at ofile:
         ; qsave
         ; close
         ; open
         ; close the ofile
         (close ofile)
Shawn T
Message 12 of 12
hmsilva
Hi shawnt,
to print the previous file, just add the print command, after the (progn
Do you need to print all layouts?
If so, try to add this code lines after the (progn
(setq adoc (vla-get-ActiveDocument (vlax-get-acad-object)))
(vlax-for layt (vla-get-layouts adoc)
   (if (not (eq (vla-get-name layt) "Model"))
      (vla-PlotToDevice (vla-get-plot adoc))
Hope this helps,
Henrique
