Creating a Mleader with MText in different position
Hello All,
I ´d like to know if there is any way to put the Mtext under the Landing Line of a MLeader. And if so How can I put it in a lisp.
I am criating a Lisp to get the coordinates and write them in a Mtext of a leader, but I need to put this text under the Landing Line and this landing line must have the lenght of the text.
Anyone could help me?
Thanks in advance
ronjonp
Perhaps an mleaderstyle like attached with an overline on the text?
Hello @Anonymous
Was it something like that?
(vl-load-com)
(defun c:Coo (/ arr aspc lead mtxt pt1 pt2 ptlst tstr)
  (if (and (setq pt1 (getpoint "\nEspecifique o local da coordenada: "))
           (setq ptlst (cons pt1 ptlst))
           (setq pt2 (getpoint pt1 "\nEspecifique o início do texto: "))
           (setq pt2 (list (car pt2) (cadr pt2) (caddr pt1)))
           (setq ptlst (cons pt2 ptlst))
    (progn
      (or *adoc (setq *adoc (vla-get-activedocument (vlax-get-acad-object))))
      (setq aspc (vla-get-activeSpace *adoc)
            aspc (cond ((= aspc 1)
                        (vla-get-modelSpace *adoc)
                       ((= aspc 0)
                        (if (= (getvar "CVPORT") 1)
                          (vla-get-block (vla-get-activelayout *adoc))
      (vla-startundomark *adoc)
      (setq ptlst (reverse ptlst)
            tstr  (strcat (strcat "N: " (rtos (car pt1) 2 2))
                          (strcat "\\PE: " (rtos (cadr pt1) 2 2))
                          (strcat "\\PZ=" (rtos (caddr pt1) 2 4))
            mtxt  (vla-addmtext aspc (vlax-3d-point pt2) 0.0 tstr)
      (vla-put-attachmentpoint mtxt acattachmentpointmiddleleft)
      (vla-put-height mtxt (getvar 'DIMTXT))
      (vla-put-insertionpoint mtxt (vlax-3d-point pt2))
      (setq ptlst (apply 'append ptlst)
            arr   (vlax-make-safearray vlax-vbdouble (cons 0 (- (length ptlst) 1)))
      (vlax-safearray-fill arr ptlst)
      (setq lead (vla-addleader aspc (vlax-make-variant arr) mtxt aclinewitharrow))
      (vla-put-verticaltextposition lead acvertcentered)
      (vla-update lead)
      (vla-regen *adoc acactiveviewport)
      (vla-endundomark *adoc)
  (princ)
(prompt "\nType >>COO<<")
pbejse
What is the format of the coordinates as MTEXT?
X,Y,Z
or
N:
E:
Elev:
or
X
Y
Z
