Can ATTSYNC command use in ObjectDBX, or similar solution using ObjectDBX ?
Hello All,
In my current task, I update AutoCAD electrical drawing using an ObjectDBX method but, due to some unknown reason Atttrubute sifted to a new position this problem solve by using ATTSYNC command, I write a function which writes a script which opens every drawing from the project and runs ATTSYNC command for the targeted block. but this is a time-consuming process.
I am looking to run ATTSYNC command in the ObjectDBX method without opening drawing, as far I know we can't run any command in the ObjectDBX method, so can I write some code which can be done a similar action like ATTSYNC command, any help appreciated I found on the web but no luck.
cadffm
Only add attributes to existing inserts is a problem (with lisp), for this you need a workaround.
For all other changes:
Walk through all blockreferences and there attributes,
compare it with the edited blockdefinition,
make your changes..
A short answer for a lot of work, i know in detail.
Sebastian
dgorsman
Changing attribute contents through ObjectDBX has problems when the justification is anything other than the default/left setting.  As far as I know there isn't any way to get around this without the drawing open in the editor.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
