Create regions out of different layers and place them in their correspondent layer, is it possible?
manso86
Message 1 of 8
manso86
Hi guys,
I would like to create a AutoLISP but I am still very new to it and I believe I need a lot of time, perhaps you can help?
I need to create create regions out of polylines and allocate these new regions into the layer of the polylines it was created from. The region command does the first step but it allocates all the new region in the same layers so I am trying to make the process quicker not do go one-by-one.
Could anyone help?
Accepted solutions (3)
Replies (7)
Message 2 of 8
Sea-Haven
Message 3 of 8
paullimapa
Give attached RegByLyr.lsp a try.
Routine cycles through all layers and converts closed lwpolylines to regions and changes them to the corresponding layer.
Paul Li
IT Specialist
@The Office
Message 4 of 8
komondormrex
hey,
sure it is possible
(defun c:closed_pline_region nil
	(vlax-map-collection (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
			'(lambda (object)
				(if (and
						 (= "AcDbPolyline" (vla-get-objectname object))
						 (minusp (vlax-get object 'closed))
						(progn
							(vla-put-layer
								(car (vlax-invoke (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
															  'addregion
															  (list object)
							    (vla-get-layer object)
					 		(vla-erase object)
	(princ)
Message 5 of 8
manso86
Thanks a lot @Sea-Haven , this works perfectly and very quick response!
Message 6 of 8
manso86
Hello @paullimapa awesome this also works, thanks a lot for your help! looking forward to getting into the autolisp world!
Message 7 of 8
manso86
@komondormrex Thanks a lot! you guys are awesome! very quick response and works as I wanted ! 🙏
Message 8 of 8
paullimapa
Glad to have helped. As you can see there are more than one way to get it done. That’s what’s so fascinating about programming. Enjoy the learning process and cheers!!!
Paul Li
IT Specialist
@The Office
