How to find any leader that a block may be associated with.
hawstom
Message 1 of 12
hawstom
Given the name of a block insertion A (ename: ...D00), how would I find out that it is associated with leader B (ename: ...CB0) below?
I suppose I could look through all leaders and find out if one of them has a DXF group 340 reference to block A. Is there a better way?
Block Insertion A:
((-1 . <ENTITY NAME: 1BCCB485D00>)
  (0 . INSERT)
  (5 . 21EA8)
  (102 . {ACAD_XDICTIONARY)
  (360 . <ENTITY NAME: 1BCCB485D10>)
  (102 . })
  (102 . {ACAD_REACTORS)
  (330 . <ENTITY NAME: 1BCCB485CB0>)
  (102 . })
  (330 . <ENTITY NAME: 1BCB0C061F0>)
  (100 . ACDBENTITY)
  (67 . 0)
  (410 . MODEL)
  (8 . C-ANNO-HCNM-BUBL)
  (100 . ACDBBLOCKREFERENCE)
  (66 . 1)
  (2 . *U137)
  (10 678519.0 893354.0 0.0)
  (41 . 2.0)
  (42 . 2.0)
  (43 . 2.0)
  (50 . 0.0)
  (70 . 0)
  (71 . 0)
  (44 . 0.0)
  (45 . 0.0)
  (210 0.0 0.0 1.0)
Leader B:
((-1 . <ENTITY NAME: 1BCCB485CB0>)
  (0 . LEADER)
  (5 . 21EA3)
  (360 . <ENTITY NAME: 1BCCB485CC0>)
  (102 . })
  (100 . ACDBENTITY)
  (67 . 0)
  (410 . MODEL)
  (100 . ACDBLEADER)
  (3 . STREET)
  (71 . 1)
  (72 . 0)
  (73 . 2)
  (74 . 1)
  (75 . 0)
  (40 . 0.0)
  (41 . 0.0)
  (76 . 2)
  (10 678525.0 893343.0 0.0)
  (340 . <ENTITY NAME: 1BCCB485D00>)
  (211 1.0 0.0 0.0)
  (210 0.0 0.0 1.0)
  (212 0.0 0.0 0.0)
  (213 0.0 0.0 0.0)
Replies (11)
Message 2 of 12
komondormrex
maybe you have to check every 330 group in block dxf to find target leader? or if it is the only one leader in a block get it within (102 . {ACAD_REACTORS) group?
Message 3 of 12
hawstom
That sounds feasible. I thought there might be a snazzy vla- or vlax- way so I could modernize (ActiveX-ize) my knowledge a bit.
Tom
Message 4 of 12
Kent1Cooper
How did you get the ename of the Block insertion part, not that of the MLeader?  When I make an MLeader with the Block option in an otherwise empty drawing, there are no Block insertions in the drawing [that is, (ssget "_X") cannot find any, either by INSERT object type or by Block name] -- it's an embedded part of the Mleader object.
If you want to know whether a MultiLeader has a given Block name associated with it, there's a VLA property:
ContentBlockName
that you could extract from the VLA-object conversion of the Mleader.
Kent Cooper, AIA
Message 5 of 12
hawstom
1. I am not using MLEADER because I needed block attributes exposed and I couldn't find a way to do that with MLEADER. So I am using LEADER.
2. In this exercise, I'm getting the block with (entsel). Given that insertion ename, I need the leader ename so I can get its start point.
Tom
Message 6 of 12
pendean
Community Legend
Community Legend
So you just have a "loose" leader snapped to or just floating near a block? Share a sample DWG file to go with your LISP file please.
Message 7 of 12
hawstom
Loosely associated using the LEADER Block option. It's a separate entity. But if you move the block insertion, the leader follows. That's why the block insertion has a reactor for the leader.
A drawing with a few of the blocks is attached.
I am working on edits to this open source project: https://github.com/hawstom/cnm
In this file: https://github.com/hawstom/cnm/blob/master/Devtgh/cnm.lsp
Around line 4946.
Message 8 of 12
hawstom
The code is functional at line 5065 here: https://github.com/hawstom/cnm/blob/master/Devtgh/cnm.lsp
using the hacky group 330 and 340 checking mentioned above. I go through all the group 330's and see if any of them has a 340 reference back to the block insertion.
I would still like to do this with ActiveX instead.
Message 9 of 12
hawstom
I used this method to produce apparently functional code (based on preliminary testing) as mentioned in my reply three minutes ago
Message 10 of 12
john.uhden
@hawstom .
See if this helps you...
;; Function to determine if an object (specifically of |etype)
;; is attached by standard ACAD_REACTORS to the input object:
;; added 04-12-00
(defun @cv_attached? (|e |etype / |ent |react |ref)
   (setq |ent (entget |e '("*")))
   (and (setq |react (member '(102 . "{ACAD_REACTORS") |ent))
        (setq |ref (nth 1 |react))
        (= (car |ref) 330)
        (setq |ref (cdr |ref))
        (setq |ent (entget |ref))
        (= (cdr (assoc 0 |ent)) |etype)
Ignore the pipe symbol prefixes.  They're left over from the days when local symbols weren't local at all.
John F. Uhden
Message 11 of 12
hawstom
@john.uhden, I guess what I did here is similar except that I check all 330s to see if their entity has this entity attached.
(WHILE
         ;; Check all 330 groups
         (AND
           (NOT ENAME_LEADER_OLD)
           (SETQ ENAME_330 (CDR (ASSOC 330 ELIST_BLOCK_OLD)))
         ;; Use the one that refers back to this block. Or move to the next one.
         (COND
           ((EQ (CDR (ASSOC 340 (ENTGET ENAME_330))) ENAME_BLOCK_OLD)(SETQ ENAME_LEADER_OLD ENAME_330))
           (T (SETQ ELIST_BLOCK_OLD (CDR (MEMBER (ASSOC 330 ELIST_BLOCK_OLD) ELIST_BLOCK_OLD)) ENAME_LEADER_OLD NIL))
Message 12 of 12
john.uhden
@hawstom ,
I think I remember investigating the 340 code and for some reason ended up ignoring it.  It was so long ago.
But if your code works right then my hat's off to you.  Well done!
John F. Uhden
