create a mirage ruler
k005
Advisor Advisor
k005
Hello everyone
I want to create an automatic Mira ruler. can you help me with this?  ( width: 6cm fix )
Height (cm) ? : 250
Direction (Front/Back): F
Specify  point>
front
back
Thanks in advance for the help friend.
Sea-Haven
E Face staff ?
What is problem the level staff is a repeating pattern, bothe sides, based on the E face of 10mm solids not hard to make a block, array text & block. Edit text it would be a one off so it will take longer to write program than to do it.
PS a new one is $77.
k005
Yes, you may be right. I thought of doing it as a dynamic block before I wrote a message...
However, if you want to add the Front/Back option, there must be two separate blocks. not very practical. so lisp code was my choice.
also if it happens with lisp code, I will add it to my program that I continue to develop in C #
yes, it seems a bit difficult... I think the friend who is available can help
Thank you.
k005
Let me simplify the matter a little; It's just the front too...
Jonathan3891
You can have one block and use visiblity states to have it show the front or back.
Jonathan Norton
Blog | Linkedin
k005
altitude is important. should be designed by entering this value. For this reason, the block may not be suitable.
Thanks.
