Add message box to lisp code
Mike_Y2
Message 1 of 11
Mike_Y2
Apologies in advance... I have very little experience of writing lisp code...
I have the lisp code below that runs a script file. The script file take a few minutes to run and it is not obvious to the user when the script file has finished running.
How do I add a simple message box into the lisp code, that displays after the Script file has finished running???
(defun C:Run_Script ()
(if (findfile "C:/Block data/A2 Data Output/1 Data Output.scr")
(command "_script" "C:/Block data/A2 Data Output/1 Data Output.scr")
); end if
); end function
Replies (10)
Message 2 of 11
john.uhden
@Mike_Y2 ,
The simplest way is to use the (alert) function, as in...
(alert "You picked the wrong horse, idiot!")
The alert dialog stretches (to a point) to fit your full line of text into its width, but if you think or find that it doesn't, then you can break your line into two or more lines by adding "\n" for each line feed like...
(alert "There once was a girl named Bright\nWhose speed was much faster than light.\nShe set off one day,\nIn her usual way\nAnd returned on the previous night.")
BTW, "The Man from Nantucket" is NOT the same as "The young man from Pawtucket."
The former can be told in public, but the latter should probably be reserved for adult guys only.
John F. Uhden
Message 3 of 11
komondormrex
hi,
try this
		(progn
			(alert "Script completed.")
); end if
); end function
Message 4 of 11
Mike_Y2
@komondormrex  Thanks for giving me the full code. I have just tested it and the message box appear immediately (before the script file has finished running). Is there a way to alter the message box so it appears after the script file has completed?
Message 5 of 11
Moshe-A
@Mike_Y2  hi,
it's true, AutoCAD runs the script that comes from lisp as the last command and all codes after will be in front (as you see 😀) the solution to this is to put the call to (alert) function message as  the last line in the script file.
Moshe
Message 6 of 11
john.uhden
@komondormrex ,
You could shorten that a little...
(defun C:Run_Script ( / file)
(if (setq file (findfile "C:/Block data/A2 Data Output/1 Data Output.scr"))
		(progn
			(command "_script" file)
); end if
); end function
John F. Uhden
Message 7 of 11
komondormrex
hey Mike,
think this can work also. @john.uhden counted.
			(progn
				(vla-postcommand (vla-get-activedocument (vlax-get-acad-object)) (alert "Script completed."))
	); end if
); end function
Message 8 of 11
john.uhden
@komondormrex ,
I counted what?
John F. Uhden
Message 9 of 11
komondormrex
@john.uhden
your remark has been taken into account, thus you've been counted too.
Message 10 of 11
john.uhden
@komondormrex ,
I am only one.
You have reminded me of an incident decades ago with a friend's very young twin brothers.
Mom had allowed them to have one M&M each.  One twin accused the other of taking two M&Ms.
The accused replied, "Hey, I only took one."  Then he opened his hand and said, "Here, count it!"
I laughed for days.
John F. Uhden
Message 11 of 11
Sea-Haven
You can also use Vslide for a fancy message with a Delay
(command "Vslide" "d:\\acadtemp\\yesitsfinished.sld")
(delay 1000)
(command "regen")
