create a command
create a command
Message 1 of 27
create a command
I have been working on making a command, that does the following,
erase all but the selected,
purge all.
saveas - choose file location and name.
updatefields - all.
save.
My current script looks like this:
^C^C_erase;all;r \\;z;e;-purge;a;;n;_saveas;updatefield;all;;_save;
If I end the script at "save as;"
I am able to see the save as window and can choose the location of where I want to save it,
however I don't see it when I add "updatefield;all;;_save;" to the end.
just need help getting the last bit sorted
Thanks in advance
Replies (26)
Message 2 of 27
rkmcswain
The Save command saves a copy of the current drawing but leaves you in the current drawing.
SaveAs does the same as Save, but switches you to this new copy.
Qsave simply saves the current drawing in place.
Which one are you trying to do?
More Info: http://cadpanacea.com/wp/?p=697
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 27
I would firstly like the command to SaveAs, (saves the drawing under a new name and opens this new drawing.)
Then I would like to updatefield and save (save my drawing and I stay in the drawing)
Message 4 of 27
rkmcswain
The use QSAVE as your last command.
Message 5 of 27
My problem is really in that when I add anything after the SaveAs command it does not open the window with the files so I can choose where to put it and what to save it under. why is that?
Message 6 of 27
gdefilo
Hi rkmcswain,
and hi to TimonUdaiyar too.
As you suggested, I would substitute the last "save" command with "qsave".
But firstly I would suggest to put a backslash after the "_saveas" command, so that the application will wait for the user to change the name of the file and of the directory, if necessary.
So, the macro should be:
^C^C_erase;all;r \\;z;e;-purge;a;;n;_saveas;\;updatefield;all;;_qsave;
After the first "save" it will continue updating the fields and so on.
Hope this helps,
Giancarlo
Message 7 of 27
Hello Giancarlo
I made the changes as you suggested, but I am still not getting window that I normaly get when I choose SaveAs.
please see attached screen shot pic 1 is what I get with the updafield and qsave added
without it I get pic 2
I would like to get pic 2 with the updatefield and qsave added.
Message 8 of 27
gdefilo
Hi TimonUdaiyar,
you're right.
My fault.
My macro is not correct for your purposes.
Sorry,
Giancarlo
Message 9 of 27
gdefilo
There is a little workaround but I don't think you will like it.
The macro should be changed like this:
^C^C_erase;all;r \\;z;e;-purge;a;;n;_saveas;\\updatefield;all;;_qsave;
It will work, but it will not open a dialog for the saveas command: you will be asked to write the name of the file at the command line, with the entire directory tree (for instance: "C:\My works\drawing01.dwg". Note: the quotes are for directories which contain spaces between words - like "my work").
So, it's not good for you I think.
Giancarlo
Message 10 of 27
Sofia.Xanthopoulou
Hi @Anonymous,
I have followed this discussion from the beginning, because I did some testing, too. I couldn't find any way to bring up the saveas dialogbox after the macro continues.
Maybe you should consider to split the macro. Two working commands should be better than one, that isn't even what you need Smiley Wink
Regards
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Message 11 of 27
hmsilva
Hi Timon,
if you are not on LT, try to add a 'initdia' to call the dialog...
...-purge;a;;n;(initdia);_saveas...
Untested...
Hope this helps,
Henrique
Message 12 of 27
Sofia.Xanthopoulou
Oh my god Smiley Surprised
the bracket was missing! I tried initdia so often - without a bracket! Best hint ever....
 ^C^C_erase;all;r \\;z;e;-purge;a;;n;(initdia);_saveas;\updatefield;all;;_save;
Henrique is our heroe Smiley Very Happy
Message 13 of 27
hmsilva
Hello Sofia, Smiley Happy
let's wait and see if OP is not on LT...
Cheers
Henrique
Message 14 of 27
Hello Henrique,
I am on LT
Message 15 of 27
hmsilva
@Anonymous wrote:
Hello Henrique,
I am on LT
Hello Timon,
I'm not an LT guy, will the (initdia) fails on LT?
EDIT: if fails, try
...-purge;a;;n;_saveas;;~;...
again, untested...
Hope this helps,
Henrique
Message 16 of 27
Hi Henrique,
doesn't work either,
stops after erase objects.
Message 17 of 27
Sofia.Xanthopoulou
Hi Timon,
have you copy/pasted the line from my post? I tried it, it worked.
Regards
Message 18 of 27
hmsilva
@Anonymous wrote:
Hi Henrique,
Timon,
I don't have AutoCAD in this laptop, so I can't test it...
Giancarlo have suggested:
and you answered:
'Hello Giancarlo
I would like to get pic 2 with the updatefield and qsave added.'
Was the macro run until the end or not?
Henrique
Message 19 of 27
I never saved it by manually entering the directory, when it asked me.
Message 20 of 27
hmsilva
Then the macro runs until the saveas command, correct?
If runs, try to change just an enter after the saveas and a tild and an enter after the tilde, in the working macro...
^C^C_erase;all;r \\;z;e;-purge;a;;n;_saveas;;~;\;updatefield;all;;_qsave;
Hope this helps,
Henrique
