Counting and sum of the TEXT
Gaganpatel
Message 1 of 20
Gaganpatel
Dear Sir,
I want to count and make the sum of it by the help of lisp file.
1*M16*40
2*M16*35
8*M16*50
1*M16*40
2*M16*35
2*M16*45
1*M16*6PW
1*M16*10PW
2*M16*45
2*M16*35
1*M16*10PW
1*M16*6PW
only select object text sum not total drawing text sum.
Final result will be
M16x35-6
M16x40-2
M16x45-4
PW16x6-2
PW16x10-2
Replies (19)
Message 2 of 20
Gaganpatel
Dear Sir,
1*M16*40
2*M16*35
8*M16*50
1*M16*40
2*M16*35
2*M16*45
1*M16*6PW
1*M16*10PW
2*M16*45
2*M16*35
1*M16*10PW
1*M16*6PW
M16x35-6
M16x40-2
M16x45-4
PW16x6-2
PW16x10-2
Message 3 of 20
Gaganpatel
PLEASE REPLAY
Message 4 of 20
ВeekeeCZ
What are you talking about? Tell us some background. Maybe post some screenshot or dwg.
What is M16, is it some variable? What are 6MW or 10PW? Remember we know nothing about your area, your industry, your national customs...
Message 5 of 20
Gaganpatel
Dear Sir,
Please replay
Please find the attached example file.
Message 6 of 20
ВeekeeCZ
Sorry, can't help you, don't understand you.
@Anonymous LOOK HERE for more context.
Message 7 of 20
Gaganpatel
dear sir,
text writing will be changed
old text
M16x45-12
M16x50-8
M16x55-4
new text
1*M16*40
2*M16*35
8*M16*50
1*M16*40
2*M16*35
2*M16*45
1*M16*6PW
i am trying old lisp file but not working
please help
Message 8 of 20
pbejse
please help
Perhaps this one  MULTI TYPES OF TEXT SUM by DannyNL
Message 9 of 20
pbejse
Would love to help, but apparently, I did not even come up with a solution for that 😄
Message 10 of 20
Gaganpatel
Dear sir,
text writing will be changed.
old text
1-C
2-D
5-A
new text
2*M16*35
2*M16*45
1*M16*6PW
1*M16*10PW
2*M16*45
2*M16*35
1*M16*10PW
i am trying this lisp but not working
please help .
Message 11 of 20
Gaganpatel
Please any body answer
please help
Message 12 of 20
CADaSchtroumpf
With your example, seem to work...
Try it if can help you
((lambda ( / js M16*40 M16*45 M16*50 M16*55 n en dxf_txt)
  (setq js (ssget "_X" '((0 . "TEXT") (67 . 0) (8 . "Bolt_Qty") (62 . 40) (7 . "BoltNut"))))
  (cond
    (js
      (setq M16*40 0 M16*45 0 M16*50 0 M16*55 0)
      (repeat (setq n (sslength js))
        (setq
          ent (ssname js (setq n (1- n)))
          dxf_txt (cdr (assoc 1 (entget ent)))
        (foreach el '("?`*M16*40" "?`*M16*45" "?`*M16*50" "?`*M16*55")
          (if (wcmatch dxf_txt el)
            (set (read (substr el 4)) (1+ (eval (read (substr el 4)))))
  (mapcar '(lambda (x) (print (strcat x "-" (itoa (eval (read x)))))) '("M16*40" "M16*45" "M16*50" "M16*55"))
  (prin1)
Message 13 of 20
Gaganpatel
Dear Sir,
Not only M16 bolt
M20*55*5
M20*85*2
M20*65*5
Message 14 of 20
Gaganpatel
Please help me sir
Message 15 of 20
dbhunia
Try this......(Considering all Bolts are in Layer "Bolt_Qty")
(defun C:BCNT (/ Toatl);;Add Temp variables here
(setq Bolt_lst (list "M16*6" "M16*35" "M16*40" "M16*45" "M20*55" "M20*65" "M20*85" "16*6PW"));;Add Bolts Here in this format
(setq selectionset (ssget "_A" '((0 . "TEXT") (8 . "Bolt_Qty"))))
(foreach b Bolt_lst
   (setq count 0)
   (repeat (setq N (sslength selectionset))
	(setq Data (ssname selectionset (setq N (- N 1))))
	(setq EntityData (entget Data))
	(setq text (cdr (assoc 1 EntityData)))
	(if (/= (vl-string-search b text) nil)
	    (progn
		(setq text_lst (LM:str->lst text "*"))
		(setq no (atoi (nth 0 text_lst)))
		(setq count (+ count no))
   (if (= (vl-string-search "PW" b) nil)
   	(print (setq result (strcat (vl-string-subst "X" "*" b) "-" (rtos count))))
	(progn
		(print (setq result (strcat "PW" (vl-string-subst "" "PW" result))))
   (setq Toatl (cons result Toatl))
(print Toatl)
(princ)
(defun LM:str->lst ( str del / len lst pos )
    (setq len (1+ (strlen del)))
    (while (setq pos (vl-string-search del str))
	   (setq lst (cons (substr str 1 pos) lst))
           (setq str (substr str (+ pos len)))
    (reverse (cons str lst))
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 16 of 20
Gaganpatel
Dear Sir,
This lisp not working in command BCNT
Message 17 of 20
dbhunia
This is working with your attached drawing to me.......(AutoCAD 2018)......
Try this.....
(vl-load-com)
(setvar 'cmdecho 0)
(foreach b Bolt_lst
   (setq count 0)
	    (progn
	(progn
(setq txtpt (getpoint "\nSelect location to print Calculation:"))
(command "text" txtpt "" "%%uBolt Summation:")
(foreach Item (reverse Toatl)
       (command "_TEXT" "" Item)
(setvar 'cmdecho 1)
(princ)
What message you are getting???????
Debashis Bhunia
Message 18 of 20
Gaganpatel
This lisp is working ok but i want to option
selecting drawing bolt counting option not total drawing bolt count.
please help.
Message 19 of 20
dbhunia
please help.
change....this
To.....
(setq selectionset (ssget '((0 . "TEXT") (8 . "Bolt_Qty"))))
Debashis Bhunia
Message 20 of 20
Gaganpatel
Thank you very much sir
