Counting and sum of the objects
Gaganpatel
Message 1 of 19
Gaganpatel
Dear Sir,
I want to count and make the sum of it by the help of lisp file. For example in drawing we have
3*M16x40
5*M16x45
4*M16x55
8*M16x50
6*M16x40
7*M16x45
Final result will be
M16x40-9
M16x45-12
M16x50-8
M16x55-4
Replies (18)
Message 2 of 19
pbejse
(Defun c:demo ( / Text alldata ss textlocation f entdata str qty label)
(defun Text (pt sty hgt str)
  (entmakex (list (cons 0 "TEXT")
                  (cons 10  pt)
		  (cons 7 sty)
                  (cons 40 hgt)
                  (cons 1  str))))
	(if
	  (and
	    (setq alldata nil
		 ss (ssget "_X" '((0 . "TEXT")(8 . "bolts length")(1 . "*#`*M*"))))
	    (setq textlocation (getpoint "\nText location"))
		(progn
		  	(repeat (setq i (sslength ss))
			  	(setq entdata (entget (ssname ss (setq i (1- i)))))
			  	(setq str (cdr (assoc 1 entdata)))
			  	(setq qty (atoi str))
			  	(setq label (substr str (+ 2 (1+ (fix (/ (log qty) (log 10)))))))
			  	(setq alldata
			  	(if (setq f (assoc label alldata))
				  	(subst (list label (+ (cadr f) qty)) f alldata)
					(cons (list label qty) alldata)))
		  (setq tstyle (cdr (assoc 7 entdata))
	                theight (cdr (assoc 40 entdata)))
		  (foreach itm (vl-sort alldata '(lambda (a b)(< (car a)(car b))))
		    	(Text textlocation tstyle theight
			      (strcat (car itm) "-" (itoa (cadr itm))))
		    	(setq textlocation (polar textlocation (* pi 1.5) (* theight 2.0))))
  (princ)
Message 3 of 19
Gaganpatel
Dear Sir,
Please  Modify count and make the sum of it by the help of lisp file. For example in drawing we have.
out put result for select object not total drawing file
3*M16x40
5*M16x45
4*M16x55
8*M16x50
2*PW16*8
6*M16x40
7*M16x45
1*PW16*10
M16x40-9
M16x45-12
M16x50-8
M16x55-4
PW16*8-2
PW16*10-10
Message 4 of 19
pbejse
@Gaganpatel wrote:
M16x40-9
M16x45-12
M16x50-8
M16x55-4
PW16*8-2
PW16*10-10
Replace this
(setq alldata nil
with this
(setq alldata nil
		 ss (ssget "_X" '((0 . "TEXT")(8 . "bolts length")(1 . "*#`*@*"))))
HTH
Message 5 of 19
Gaganpatel
Dear Sir,
output result for select object not total drawing file
Message 6 of 19
pbejse
Replace this
(setq alldata nil
with this
(setq alldata nil
		 ss (ssget '((0 . "TEXT")(8 . "bolts length")(1 . "*#`*@*"))))
HTH
Message 7 of 19
Gaganpatel
 Dear Sir,
This problems solve but output result only select drawing not total drawing.
M16x40-9
M16x45-12
M16x50-8
M16x55-4
PW16*8-2
PW16*10-10
Message 8 of 19
Gaganpatel
Dear Sir,
Please solve
Message 9 of 19
Gaganpatel
Dear Sir,
Please solve
output result only select drawing.
please see the example video.
Message 10 of 19
pbejse
Replace
I understand what is required
With
I'm NOT understanding  what is required
Seriously
Message 11 of 19
Gaganpatel
I Require command demo then select object and output text location.
Message 12 of 19
Gaganpatel
Please solve
Message 13 of 19
pbejse
Tell you what
Post 2 sample drawings. Before and After
Message 14 of 19
Gaganpatel
Yes
two drawing  one drawing required bolt counting, next drawing not required.
then bolt required drawing select output text.
Message 15 of 19
Gaganpatel
Dear Sir,
Please see the attached drawing and solve
Message 16 of 19
pbejse
I still don't understand what that means at ALL.
Attached a drawing sample of a BEFORE the program run  and AFTER [ as the RESULT ]
EDIT: LEt me check the drawing file you just uploaded.
That is exactly what the code is supposed to do, that is if you follow the instructions from the previous posts.
Message 17 of 19
Gaganpatel
Dear Sir,
 this program run for all text counting.
but i require only select object text counting.
Message 18 of 19
Gaganpatel
Thank You very much sir.
Message 19 of 19
pbejse
You are welcome.
