Copyblock3 fix bug so scale works
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi There,
The below lisp works well but wanting the the scale option to work for me, it automatically picks 1 when I use the option.
appreacte anyone that can help me on this one.
Allan
;VVA
;make a copy of a block with a new name
;select block to copy
;enter new name unless anonymous block, then new name = ols name less *
;pick insertion point
(defun C:CopyBlock3 (/ *error* OldBlockName NewBlockName
rewind BlockName Info BlockInfo ent_name ent_info)
(defun *error* (Msg)
(cond
((or (not Msg)
(member Msg '("console break"
"Function cancelled"
"quit / exit abort"))))
((princ (strcat "\nError: " Msg)))
) ;cond
(princ)
) ;end error
(sssetfirst)
(setq OldBlockName (entsel "\nSelect Block to copy: "))
(while
(or
(null OldBlockName)
(/= "INSERT" (cdr (assoc 0 (entget (car OldBlockName)))))
(princ "\nSelection was not a block - try again...")
;block name
(setq OldBlockName (strcase (cdr (assoc 2 (entget (car OldBlockName))))))
(princ (strcat "\nSelected block name: " OldBlockName))
(if (= "*" (substr OldBlockName 1 1))
(setq NewBlockName (substr OldBlockName 2))
(setq NewBlockName (getstring T "\nEnter new block name: "))
(setq rewind T)
(while (setq Info (tblnext "BLOCK" rewind))
(setq BlockName (strcase (cdr (assoc 2 Info))))
(if (= OldBlockName BlockName)
(setq BlockInfo Info)
(setq rewind nil)
(if BlockInfo
(progn
(setq ent_name (cdr (assoc -2 BlockInfo)))
;header definition:
(entmake (list '(0 . "BLOCK")
(cons 2 NewBlockName)
'(70 . 2)
(cons 10 '(0 0 0))
;body definition:
(entmake (cdr (entget ent_name)))
(while (setq ent_name (entnext ent_name))
(setq ent_info (cdr (entget ent_name)))
(entmake ent_info)
;footer definition:
(entmake '((0 . "ENDBLK")))
(command "-INSERT" NewBlockName pause "1" "1" "0")
(*Error* nil)
(princ)
) ;end
