Change layer color in multiple AutoCAD drawings at one time.
lisa_as-caddtech
lisa_as-caddtech
I would like to change the color of 1 layer (Equipment) from black to blue in over 200 AutoCAD drawings without opening each drawing and manually changing it.  I have heard I can do that in Hurricane for AutoCAD but I have not had the time to try it out and I have not found a tutorial for it.  Does anyone have a good step-by-step instructions I could use?
TIA LSmith
pendean
Community Legend
Community Legend
@lisa_as-caddtech wrote:
...Hurricane for AutoCAD but I have not had the time to try it out and I have not found a tutorial for it...
Here you go from that vendor's website:
https://74mph.com/tutorials.html
quick start:
https://www.youtube.com/watch?v=BA214zKGGJg
How to write a script (so you can write a "change a layer color in xxxx files")
https://www.youtube.com/watch?v=PHiCVg7d7eg
How to use LAYER command in a script to change a layer color:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/how-can-i-change-a-layers-color-usin...
HTH
Kent1Cooper
How about something that will change it automatically in every drawing that is opened for any reason?  It wouldn't change it in a given drawing until it is opened, but would that be enough?  A single line of code in an acaddoc.lsp file can handle that:
(command "_.layer" "_color" 5 "Equipment" "")
It won't care if a given drawing does not contain that Layer.
[The "from" color of the Layer doesn't matter.  But if you would only want it changed to blue if it is currently black, that could be accommodated.]
Kent Cooper, AIA
DGCSCAD
If all drawings reside in one single directory, this should take care of it:
(defun c:Batcher (/ wutdir wutfiles scrfile n2 scrline)
(vl-load-com)
	(setq wutdir (LM:browseforfolder "Select directory to process:" "C:\\" 512));;;<--Starting Directory
	(setq wutfiles (vl-directory-files wutdir "*.dwg"))
	(setq scr_name (strcat wutdir "\\scrfile.scr"))
	(setq scrfile (open scr_name "w"))
	(close scrfile)
	(setq scrfile (open scr_name "a"))
(foreach n wutfiles
	(setq n2 (strcat "\""wutdir "\\" n "\""))
	(setq n2 (vl-string-translate "\\" "\\" n2))
	(setq scrline (strcat "open" " " n2 " " "(load\"batcher\")" " " "(batcher_layer_chgclr)" " " "qsave" " " "close"))
	(write-line scrline scrfile)
	(princ)
	(close scrfile)
(command "script" scr_name)
(princ "\n***Batch complete.***")
(princ)
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;START batcher_layer_chgclr
(defun batcher_layer_chgclr ()
(princ)
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;START LM:browseforfolder
;; THANKYOU Mr. M!
;; Browse for Folder  -  Lee Mac
;; Displays a dialog prompting the user to select a folder.
;; msg - [str] message to display at top of dialog
;; dir - [str] [optional] root directory (or nil)
;; bit - [int] bit-coded flag specifying dialog display settings
;; Returns: [str] Selected folder filepath, else nil.
(defun LM:browseforfolder ( msg dir bit / err fld pth shl slf )
    (setq err
        (vl-catch-all-apply
            (function
                (lambda ( / app hwd )
                    (if (setq app (vlax-get-acad-object)
                              shl (vla-getinterfaceobject app "shell.application")
                              hwd (vl-catch-all-apply 'vla-get-hwnd (list app))
                              fld (vlax-invoke-method shl 'browseforfolder (if (vl-catch-all-error-p hwd) 0 hwd) msg bit dir)
                        (setq slf (vlax-get-property fld 'self)
                              pth (vlax-get-property slf 'path)
                              pth (vl-string-right-trim "\\" (vl-string-translate "/" "\\" pth))
    (if slf (vlax-release-object slf))
    (if fld (vlax-release-object fld))
    (if shl (vlax-release-object shl))
    (if (vl-catch-all-error-p err)
        (prompt (vl-catch-all-error-message err))
        pth
(princ)
I'd backup the folder first, just for safety purposes. Make sure the LISP file resides in one of your support paths, and if you need assistance in loading and running a LISP file: https://www.lee-mac.com/runlisp.html
Edit (my apologies, I forgot a few key notes):
  1. Copy/Paste the code into a txt file and name it Batcher.lsp.
  2. Place Batcher.lsp in a support/trusted directory.
  3. Run the code from a drawing that will not be in the directory. Start a new drawing and run it from there.
AutoCad 2018 (full)
Win 11 Pro
paullimapa
You could also look into AutoCAD Core Console:
https://www.houseofbim.com/posts/son-of-a-batch-autocad-core-console-through-lisp/
Paul Li
IT Specialist
@The Office
lisa_as-caddtech
Thanks!  I will try all these great suggestions.
