Copy values from one Attribute block to selected block
karthur1
Mentor Mentor
Message 1 of 22
karthur1
We have updated our BOMs and now the columns are a different spacing. When we copy the BOM's from an older drawing to this new format, the rows do not line-up correctly. To fix this, we have to copy/paste each value of the attribute block from the old block to the new block.
What I would like to do is run a lisp command, then select the old block, then select the new block and it then copies all the values from the old to the new.  Even if the value in the old block is <blank>, it still is copied.
I found this (see attached), but it only copies the one value that is selected an not ALL 5 of the values in the block.  How can I make this copy/paste all the values in my block?
Kirk
Accepted solutions (3)
Replies (21)
Message 2 of 22
pendean
Community Legend
Community Legend
@karthur1 wrote:
We have updated our BOMs and now the columns are a different spacing. When we copy the BOM's from an older drawing to this new format, the rows do not line-up correctly....
May I ask, why not fix the source of the problem to start with?
Which "BOMs" and which variant of AutoCAD are you using please?
While you wait for others to help with your LISP quest of course.
Message 3 of 22
karthur1
"why not fix the source"... I am trying to standardize on a BOM format. Over the years there have been several different ones created with different width rows.
We are using just vanilla AutoCAD.
Message 4 of 22
paullimapa
try Att2Att.lsp
; Att2Att takes attribute values from source Block and places to matching tags in target Block
; OP:
; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/copy-values-from-one-attribute-block-to-selected-block/m-p/12899135#M468702
(defun C:Att2Att (/ attlst1 attlst2 atttag lst ss1 ss2 tmp)
(vl-load-com)
 (while (not ss1)
  (princ"\nSelect Source Block with Attributes...")
  (setq ss1 (ssget "_+.:E:S" '((0 . "INSERT")(66 . 1))))
 ) ; while
 (while (not ss2)
  (princ"\nSelect Target Block with Attributes...")
  (setq ss2 (ssget "_+.:E:S" '((0 . "INSERT")(66 . 1))))
 ) ; while
 (if (and ss1 ss2)
  (progn
    (setq attlst1 (vlax-invoke (vlax-ename->vla-object (ssname ss1 0)) 'getattributes) ; get source attributes
          attlst2 (vlax-invoke (vlax-ename->vla-object (ssname ss2 0)) 'getattributes) ; get target attributes
    (foreach itm attlst1 ; get from source list of assoc pair of tag and val
     (setq lst (append lst (list (cons (strcase (vla-get-tagString itm)) (vla-get-textString itm)))))
    ) ; foreach
    (foreach itm attlst2 ; get from target list tag and see if there's match to source tag then place value
     (setq atttag (strcase (vla-get-tagString itm)))
     (if (setq tmp (assoc atttag lst)) ; if matching tag
      (vla-put-textString itm (cdr tmp)) ; put source att value to target
    ) ; foreach
  ) ; progn
 ) ; if
 (princ) ; clean exit
) ; defun
Paul Li
IT Specialist
@The Office
Message 5 of 22
karthur1
After I load this, it gives me this error.
Message 6 of 22
paullimapa
I updated my previous post and also attached lsp in this post
Paul Li
IT Specialist
@The Office
Message 7 of 22
Sea-Haven
Just a question as no dwg to look at is the 2nd block mimicking a table ? If so why not use a table ? Lots of examples about read block attributes and make a table.
Message 8 of 22
karthur1
Paul,
I updated the code and it runs. When I copy the contents of the first source to the first target block it works great. But then when I select the second source and target, it copies the contents from the first source to the second target.
I have included a sample drawing here.  In the BOM, I want to be able copy the contents from say line item 1 to line item 5, then copy the contents of line item 2 to item 6.... etc.  It will be in no particular order, but I will have multiple ones to copy.
Thanks.
Message 9 of 22
komondormrex
check this one modified
(defun c:copypasteattribattribbytag ( / source_block source_block_object
										 target_block target_block_object target_attribute_found
 	(vl-load-com)
   	(while (setq source_block (car (entsel "\nPick source block bom_num to copy values from - ENTER TO FINISH...")))
		(setq source_block_object (vlax-ename->vla-object source_block))
   	 	(setq target_block (car (entsel "\nPick destination block bom_num to paste values to...")))
   	 	(setq target_block_object (vlax-ename->vla-object target_block))
		(mapcar '(lambda (source_attribute)
						 (if (vl-some '(lambda (target_attribute) (= (vla-get-tagstring source_attribute) (vla-get-tagstring (setq target_attribute_found target_attribute))))
									   (vlax-invoke target_block_object 'getattributes)
							 (vla-put-textstring target_attribute_found (vla-get-textstring source_attribute))
				 (vlax-invoke source_block_object 'getattributes)
  	(princ)
Message 10 of 22
karthur1
 	(vl-load-com)
  	(princ)
That works, but it only copies one of the attributes to my destination. In order to get all of the attributes copied for each block, I have to do this 5 times per block. I want to be able to copy the values all attributes from one block to another.
Message 11 of 22
komondormrex
surely not, as it was programmed to copy/paste values of ALL similar tag attributes from source block to target block.
or maybe you want something different.
Message 12 of 22
paullimapa
forgot to localize the variable lst.
now it should work...I've updated the lisp in my previous posts changing this line from:
(defun C:Att2Att (/ attlst1 attlst2 atttag ss1 ss2 tmp)
to adding lst in the code:
Now it should use a new lst variable when the lisp runs each time.
Paul Li
IT Specialist
@The Office
Message 13 of 22
pbejse
Are you looking into bumping the values one number up? but it should leave the ITEM (MK#) as is Yes?
Message 14 of 22
karthur1
I am not sure what happened, but I re-copied your lisp and tried it again.  Now it ran perfectly. Does exactly what I need.
Thank You !!!
Message 15 of 22
karthur1
Paul,
Yes, this work exactly like I wanted.
Thanks for helping with this.
Message 16 of 22
paullimapa
glad to have helped...cheers!!!
Paul Li
IT Specialist
@The Office
Message 17 of 22
karthur1
Paul,
I just tried your ATT2ATT today on a different drawing.  Now it doesn't copy the QTY column for some reason.  I have attached here a sample drawing that you can test.
Here is a short clip showing the issue also.
Message 18 of 22
paullimapa
Your Block RTAGA QTY. has a period at the end:
But your Block Bom-Assem QTY does not:
To correct this I used the Battman command and edited the Block RTAGA's QTY. to QTY
Now Att2Att.lsp will work since it needs to find the exact matching Attribute Tag name.
Paul Li
IT Specialist
@The Office
Message 19 of 22
karthur1
Paul,
Would it be possible for the lisp to not match the tag names? Could the lisp just copy the first, second, third, (or ever how many) values from the source att block and paste them into the target block? The blocks will have the same number of tags, but they may be named differently.  If it could do that, then it would work on ANY attblock in the drawing.
In the sample drawing, look down near the bottom. I tried to use the ATT2ATT to copy the values of the "Rev-Dsz" block to the "Revision Line" block. Since the tag REV tag is the only one that matches, that's the only one it copies.
Of course, I could use BATTMAN and edit the names then it works as advertised.  What I am asking may not be possible... just thought I would ask.
Thanks for the help,
Kirk
Message 20 of 22
komondormrex
that one is easier
(defun c:copy_paste_atts ( / source_block source_block_object target_block_object)
   	 	(setq target_block_object (vlax-ename->vla-object (car (entsel "\nPick destination block bom_num to paste values to..."))))
		(mapcar '(lambda (source_attribute target_attribute)
					(vla-put-textstring target_attribute (vla-get-textstring source_attribute))
  	(princ)
