Copy values from one Attribute block to selected block
karthur1
Mentor Mentor
Message 1 of 22
karthur1
We have updated our BOMs and now the columns are a different spacing. When we copy the BOM's from an older drawing to this new format, the rows do not line-up correctly. To fix this, we have to copy/paste each value of the attribute block from the old block to the new block.
What I would like to do is run a lisp command, then select the old block, then select the new block and it then copies all the values from the old to the new.  Even if the value in the old block is <blank>, it still is copied.
I found this (see attached), but it only copies the one value that is selected an not ALL 5 of the values in the block.  How can I make this copy/paste all the values in my block?
Kirk
Accepted solutions (3)
Replies (21)
Message 21 of 22
karthur1
@komondormrex wrote:
@karthur1 wrote:
Would it be possible for the lisp to not match the tag names?
that one is easier
That's a champ.  Works for several tests I made with it.
Thank you again!!
Kirk
Message 22 of 22
paullimapa
If you're interested here's an Att2Att.lsp version that automatically changes/updates all selected target blocks attribute tag names with the source block's attribute tag names and then transfers the matching values over.
Paul Li
IT Specialist
@The Office
