- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
We have updated our BOMs and now the columns are a different spacing. When we copy the BOM's from an older drawing to this new format, the rows do not line-up correctly. To fix this, we have to copy/paste each value of the attribute block from the old block to the new block.
What I would like to do is run a lisp command, then select the old block, then select the new block and it then copies all the values from the old to the new. Even if the value in the old block is <blank>, it still is copied.
I found this (see attached), but it only copies the one value that is selected an not ALL 5 of the values in the block. How can I make this copy/paste all the values in my block?
Kirk
