Copy or Rename Block Reference
Philip-John
Philip-John
I have the following lisp from Lee Mac. It's working good.
http://www.lee-mac.com/copyblock.html
Currently running "CB" command it creates a copy of block and paste in same place and ask for new name.
But I need, somebody can modify, it to copy and paste in another location (where I choose) then ask for new name.
Philip John
dbhunia
I think the attached LISP (Modified) may fulfill your requirement.......
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Philip-John
Thanks..
It's ok somewhat...
It is appreciable if you could make it as I requested (paste then ask for new name)
Kent1Cooper
@Philip-John wrote:
.... if you could make it as I requested (paste then ask for new name)
Here's a version of a duplicate-Block routine of mine, edited to work as you describe.  [The original replaced  the selected Block in place  by one with the new name -- this has you Copy it, using its insertion point as the Copy-displacement base point, and then does the same with the copied one in the new location.]
It has some nice features [I think] -- it offers you the current name with a hyphenated-number suffix, to edit as you like, so it it's a long name and you want to change only a little of it, you don't need to type in the whole thing.  If the Block name with the hyphenated-number suffix is already used, it counts up from there until it finds a not-yet-used number.  And it deals appropriately with other-than-1 scale factors and other-than-zero rotation.  See further comments at the top of the file.
Kent Cooper, AIA
dbhunia
@Philip-John wrote:
Thanks..
It's ok somewhat...
In that case you have to copy the block with new name and then rename it ....... that will solve your requirement.......
Then check the attached LISP .......
Debashis Bhunia
Philip-John
Thanks Debashis Bhunia
Philip-John
Thanks Kent Cooper
