Double offset
Double offset
attili.m
Double offset
attili.m
Since forever I miss one of the most (to myself) used commands: double offset.
I made a lisp program in order to fix this lack.
I often need lines straddling to a reference (usually an axis) and I am forced to calculate the half of the distance, launch the offset command, click two times (one for each side); for pipe profile, for external profiles of plate, for lateral view of p.c.d., etc.
Moreover, unlike to classic offset command, it is useful generate new geometry in the current layer, not based on the source geometry layer!
My lisp program do it!
It's possible to improve Autocad with this new command?
Kent1Cooper
@attili.m wrote:
.... unlike to classic offset command, it is useful generate new geometry in the current layer, not based on the source geometry layer! ....
[I have had an Offset-to-Both-Sides command defined for years, too.]
Perhaps you are not aware that in more recent versions of AutoCAD, there is  an option to have the results on either the source Layer or the current Layer:
Command: .OFFSET
Current settings: Erase source=No Layer=Source OFFSETGAPTYPE=0
Specify offset distance or [Through/Erase/Layer] <Through>: L
Enter layer option for offset objects [Current/Source] <Source>: C
Specify offset distance or [Through/Erase/Layer] <Through>:  ....{continue}....
But this isn't the right place to make suggestions / requests for changes in the program.  Go to the Product Feedback page.
Kent Cooper, AIA
Sea-Haven
There is plenty of code for convert a single to multi offset out there, I know I wrote a do as many as you like, its input is pick pline then type offsets so 3,-3 would draw a double for a road with kerbs say -3.45,-3,3,3.45 would draw 4 lines. It just uses csv for its input
Fleww
This is best lisp for it. You can offset like whole drawing.
