Copy Layout's ViewPort Layers settings to selected Layout (each Viewport)
jtm2020hyo
Message 1 of 10
jtm2020hyo
Anyone know if there exist any lisp to Copy ViewPort's layer settings to Selected Layout's Viewports?
S78QeG
Something like this:
1 Activate the first Layout to change
2 double click to ViewPort
2 Thaw/ Freeze your layers (viewport)
3 Run AutoLisp routine
4 Copy the configuration to all selected Layouts
Accepted solutions (3)
Replies (9)
Message 2 of 10
ВeekeeCZ
Message 3 of 10
jtm2020hyo
Awesome lisp, How can I apply to each ViewPorts inside the select Layouts?
Message 4 of 10
ВeekeeCZ
Here's the adjusted code for multiple selection.
(defun c:VPV (/ tempstr int smallstr vpent laylist vpss idx) ;ViewPort (V)paste
  (if (setq laylist (vl-bb-ref 'vpc_laylist))
    (progn
      (setq oldecho (getvar "cmdecho"))
      (setvar "cmdecho" 0)
      (command "_undo" "_be")
      (if (setq vpss (ssget '((0 . "VIEWPORT"))))
	(repeat (setq idx (sslength vpss))
	  (setq vpent (ssname vpss (setq idx (1- idx))))
	  (setq tempstr "")
	  (foreach x laylist
	    (setq tempstr (strcat tempstr x ",")))
	  (setq tempstr (substr tempstr 1 (- (strlen tempstr) 1)))
	  (command "vplayer" "t" "*" "s" vpent "" "")
	  (while (> (strlen tempstr) 256)
	    (setq smallstr (substr tempstr 1 256))
	    (setq int (vl-string-position (ascii ",") smallstr 0 t))
	    (setq smallstr (substr smallstr 1 int)
		  tempstr (substr tempstr (+ int 1))
	    (command "vplayer" "f" smallstr "s" vpent "" "")
	  (command "vplayer" "f" tempstr "s" vpent "" "")
      (command "_undo" "_end")
      (setvar "cmdecho" oldecho)
      );progn
    );if
  (princ)
Message 5 of 10
jtm2020hyo
Thanks lot, this work for select multiple Viewport at same Layout.
excuse me, could add an option more for select multiple Layouts? I mean, some like:
1 Select multiple Layouts (PaperSpaces)
1 Run c:VPCopy
2 Select the Viewport to Copy
3 Run new command c:VPC2LAYOUTS, to copy the stored list to all ViewPorts in the selected Layouts (PaperSpaces)
Message 6 of 10
ronjonp
1 Run c:VPCopy
Use the last function in @ВeekeeCZ code to do this:
C:VPCOPY
C:VPPASTE
C:VPAPPLY
Message 7 of 10
ВeekeeCZ
1 Run c:VPCopy
C:VPCOPY
C:VPPASTE
C:VPAPPLY
That's the one that I use most. But it does something else.
Message 8 of 10
jtm2020hyo
Any way thanks a lot, but maybe I used this routine wrong?
Could explain us a bit how use VPPASTE to multiple Layouts_Tabs? or if this is not possible?
Message 9 of 10
ВeekeeCZ
(defun c:VPVAll (/ tempstr int smallstr vpent laylist e tabs oldtab oldecho vpss idx) ;ViewPort (V)paste
    (progn
      (vlax-for o (vla-get-layouts (vla-get-ActiveDocument (vlax-get-acad-object)))
	(setq e (vlax-vla-object->ename o))
	(if (= 1 (getpropertyvalue e "TabSelected"))
	  (setq tabs (cons (getpropertyvalue e "LayoutName") tabs))))
      (setq oldecho (getvar 'cmdecho))
      (setvar "cmdecho" 1)
      (setq oldtab (getvar 'ctab))
      (foreach tab tabs
	(setvar 'ctab tab)
	(command "_.pspace")
	(if (setq vpss (ssget "_X" (list '(0 . "VIEWPORT") (cons 410 (getvar 'ctab)))))
	    (setq tempstr "")
	    (foreach x laylist
	      (command "vplayer" "f" smallstr "s" vpent "" ""))
      (setvar 'ctab oldtab)
      (setvar 'cmdecho oldecho)
      );progn
    );if
  (princ)
Message 10 of 10
jtm2020hyo
thanks for you last routine, this complete my work.
