Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Copy Layout's ViewPort Layers settings to selected Layout (each Viewport)
jtm2020hyo
Message 1 of 10
jtm2020hyo
Anyone know if there exist any lisp to Copy ViewPort's layer settings to Selected Layout's Viewports?
S78QeGS78QeG
Something like this:
1 Activate the first Layout to change
2 double click to ViewPort
2 Thaw/ Freeze your layers (viewport)
3 Run AutoLisp routine
4 Copy the configuration to all selected Layouts
Accepted solutions (3)
Replies (9)
Message 2 of 10
ВeekeeCZ
Message 3 of 10
jtm2020hyo
Awesome lisp, How can I apply to each ViewPorts inside the select Layouts?
Message 4 of 10
ВeekeeCZ
Here's the adjusted code for multiple selection.
(defun c:VPV (/ tempstr int smallstr vpent laylist vpss idx) ;ViewPort (V)paste
  (if (setq laylist (vl-bb-ref 'vpc_laylist))
    (progn
      (setq oldecho (getvar "cmdecho"))
      (setvar "cmdecho" 0)
      (command "_undo" "_be")
      (if (setq vpss (ssget '((0 . "VIEWPORT"))))
	(repeat (setq idx (sslength vpss))
	  (setq vpent (ssname vpss (setq idx (1- idx))))
	  (setq tempstr "")
	  (foreach x laylist
	    (setq tempstr (strcat tempstr x ",")))
	  (setq tempstr (substr tempstr 1 (- (strlen tempstr) 1)))
	  (command "vplayer" "t" "*" "s" vpent "" "")
	  (while (> (strlen tempstr) 256)
	    (setq smallstr (substr tempstr 1 256))
	    (setq int (vl-string-position (ascii ",") smallstr 0 t))
	    (setq smallstr (substr smallstr 1 int)
		  tempstr (substr tempstr (+ int 1))
	    (command "vplayer" "f" smallstr "s" vpent "" "")
	  (command "vplayer" "f" tempstr "s" vpent "" "")
      (command "_undo" "_end")
      (setvar "cmdecho" oldecho)
      );progn
    );if
  (princ)
Message 5 of 10
jtm2020hyo
Thanks lot, this work for select multiple Viewport at same Layout.
excuse me, could add an option more for select multiple Layouts? I mean, some like:
1 Select multiple Layouts (PaperSpaces)
1 Run c:VPCopy
2 Select the Viewport to Copy
3 Run new command c:VPC2LAYOUTS, to copy the stored list to all ViewPorts in the selected Layouts (PaperSpaces)
Message 6 of 10
ronjonp
1 Run c:VPCopy
Use the last function in @ВeekeeCZ code to do this:
C:VPCOPY
C:VPPASTE
C:VPAPPLY
Message 7 of 10
ВeekeeCZ
1 Run c:VPCopy
C:VPCOPY
C:VPPASTE
C:VPAPPLY
That's the one that I use most. But it does something else.
Message 8 of 10
jtm2020hyo
Any way thanks a lot, but maybe I used this routine wrong?
Could explain us a bit how use VPPASTE to multiple Layouts_Tabs? or if this is not possible?
Message 9 of 10
ВeekeeCZ
(defun c:VPVAll (/ tempstr int smallstr vpent laylist e tabs oldtab oldecho vpss idx) ;ViewPort (V)paste
    (progn
      (vlax-for o (vla-get-layouts (vla-get-ActiveDocument (vlax-get-acad-object)))
	(setq e (vlax-vla-object->ename o))
	(if (= 1 (getpropertyvalue e "TabSelected"))
	  (setq tabs (cons (getpropertyvalue e "LayoutName") tabs))))
      (setq oldecho (getvar 'cmdecho))
      (setvar "cmdecho" 1)
      (setq oldtab (getvar 'ctab))
      (foreach tab tabs
	(setvar 'ctab tab)
	(command "_.pspace")
	(if (setq vpss (ssget "_X" (list '(0 . "VIEWPORT") (cons 410 (getvar 'ctab)))))
	    (setq tempstr "")
	    (foreach x laylist
	      (command "vplayer" "f" smallstr "s" vpent "" ""))
      (setvar 'ctab oldtab)
      (setvar 'cmdecho oldecho)
      );progn
    );if
  (princ)
Message 10 of 10
jtm2020hyo
thanks for you last routine, this complete my work.
