Copy images in current drawing to selected folder
DC-MWA
Message 1 of 10
DC-MWA
I have an extensive list of drawings in which I need to gather all the referenced images in each drawing and copy them to a new directory.
I started to franken-lisp something together and realized as I often do that this is way out of my league. I'm hoping someone out there has done something similar.
I have attached what I have (not much).
Thank you in advance for any assistance received.
Replies (9)
Message 2 of 10
pbejse
Does that include subfolders?
Message 3 of 10
DC-MWA
No.
Get list of images from current drawing.
select folder to copy to
copy each image to selected folder
and now that I'm doing this, if I could rename the image name with an "X-" on the front of the image name that would be awesome.
Message 4 of 10
pbejse
@DC-MWA wrote:
No.
(defun c:copydwgimages (/ ss i image file  images)
  (vl-load-com)
  (and
    (setq ss (ssget "X" '((0 . "IMAGE"))))
    (setq i 0)
    (repeat (sslength ss)
      (setq image (vlax-ename->vla-object (ssname ss i))
	    name  (vla-get-name image)
	    file  (vla-get-imagefile image)
	    i	  (1+ i)
      (if (not (member file images))
	(setq images (cons file images))
      images
    (setq dir-loc (acet-ui-pickdir
		    "Select Files to XREF"
    (foreach itm images
      (setq p (vl-string-position 92  itm nil T))
	(vl-file-copy
		itm
		(strcat	dir-loc
			"\\" "X-" (substr itm (+ 2 p))
      (vl-file-copy
	itm
	(strcat	dir-loc
		"\\" "X-"
		(vl-filename-base itm)
		(vl-filename-extension itm)
  (princ)
HTH
Message 5 of 10
DC-MWA
I just tested it on my first drawing. It seems to work perfectly!!!
Message 6 of 10
pbejse
That's good to know, Glad it helps.
Cheers
Message 7 of 10
DC-MWA
After I do the copying of the files, I then open the savedas drawing and rename all the images to "X-imagename" and remove the paths.
Is this something we could do or should I start another post?
Message 8 of 10
pbejse
Sure we can.
BTW please ignore the post #4 as i tried to modify it and i run out of time
This version will save the drawing on the selected folder where the new renamed images are located
(defun c:copydwgimages (/ aDoc ss i image file  images)
(vl-load-com)
(setq aDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
  (if
    (and
      (setq i 0)
	      i	    (1+ i)
	(if (not (assoc file images))
	  (setq images (cons (list file image) images))
	images
      (setq dir-loc (acet-ui-pickdir "Select Files to XREF"))
     (progn
       (Vla-saveas
	 aDoc
	 (strcat dir-loc "\\" (Vla-get-name aDoc))
       (foreach	itm images
	 (setq NameAndPath (car itm))
	 (vl-file-copy
	   NameAndPath
	   (strcat dir-loc
		   "X-"
		   (setq xname (vl-filename-base NameAndPath))
		   (vl-filename-extension NameAndPath)
	 (vla-put-name (cadr itm) (strcat "X-" xname))
	 (vla-put-imagefile
	   (cadr itm)
	   (strcat ".\\"
		   (strcat "X-" xname)
  (princ)
HTH
Message 9 of 10
DC-MWA
This is exactly what I was looking for. I truly appreciate your time and knowledge. This will save me counless hours of time.
THANK YOU SO MUCH!!
Message 10 of 10
pbejse
THANK YOU SO MUCH!!
My pleasure, glad it helps
Cheers
