Hola, alguien sabe como se puede definir un sufijo en un estilo de acotado mediante un codigo lisp con entmake.
tengo el siguiente codigo pero quiero agrega un texto delante de la cota.
(defun creadim (altura /)
(setq
Dim_Name "Estilo_Cotas"
DIMBLK-Name "Oblique" ;archtick ClosedFilled
dimscale 1.0
quote_scale 1 ;scala di quota
Arrow_Size 0.05
Center_Mark_Size 0.0625
Decimal_Places 2
Dimension_Line_Spacing 0.0
Extension_Above_Dimension_Line 0.0
Extension_Line_Origin_Offset 0.0
Gap_From_dimension_Line_to_Text 0.0
Tolerance_Decimal_places 2
Text_Movement 0
Text_Font "SIMPLEX.SHX"
Text_Height altura
(command "_-style" "Estilo_Cotas" "SIMPLEX.SHX" "0" "1" "" "" "" "")
;(setvar "lunits" 2)
;(setvar "DIMASSOC" 1)
(setq ds
(list
(cons 0 "DIMSTYLE")
(cons 100 "AcDbSymbolTableRecord")
(cons 100 "AcDbDimStyleTableRecord")
(cons 2 Dim_Name) ;Dim style name
(cons 70 0) ; Standard flag
(cons 3 " [m]"); DIMPOST
(cons 4 ""); DIMAPOST
(cons 5 DIMBLK-Name) ;DIMBLK-Name of block instead of default arrowhead
(cons 6 DIMBLK-Name);(cons 6 "ClosedFilled"); DIMBLK1
(cons 7 "");(cons 7 DIMBLK-Name); DIMBLK2
(cons 170 0) ;DIMALT-turns off alternate units
(cons 40 dimscale) ;DIMSCALE-sets the overall scale factor applied to all dimensions
(cons 41 Arrow_Size) ;DIMASZ-sets the size of the arrow/tick
(cons 42 Extension_Line_Origin_Offset); DIMEXO
(cons 43 Dimension_Line_Spacing); DIMDLI
(cons 44 Extension_Above_Dimension_Line) ;DIMEXE-specifies how far to extend the extention line beyound the dim line
(cons 45 0.0); DIMRND
(cons 46 0) ;DIMDLE-sets the distance the dimension line extends beyond the extension line
(cons 47 0.0); DIMTP
(cons 48 0.0); DIMTM
(cons 71 0); DIMTOL
(cons 72 0); DIMLIM
(cons 73 0) ;DIMTIH-controls the position of dimension text inside extention lines ;METTE IL TESTO DI QUOTA ORIZZONTALE
(cons 74 0) ;DIMTOH-controls the position of dimension text outside extention lines
(cons 75 1); DIMSE1 ;1 sopprime la linea di estensione, 0 la lascia
(cons 76 1); DIMSE2 ;1 sopprime la linea di estensione, 0 la lascia
(cons 77 1) ;DIMTAD-controls the vertical position of text in relation to the dim line
(cons 78 3) ;DIMZIN-controls the suppression of zeros
(cons 79 1); DIMAZIN
(cons 140 Text_Height) ;DIMTXT-specifies the height of the text in the dim
(cons 141 Center_Mark_Size); DIMCEN
(cons 142 0.0); DIMTSZ
(cons 143 0.5) ;DIMALTF-controls the scale factor for alt. units
(cons 144 quote_scale); DIMLFAC ;scala di quota
(cons 145 0.0); DIMTVP
(cons 146 0.64); DIMTFAC
(cons 147 Gap_From_dimension_Line_to_Text) ;DIMGAP-sets the distance from around the dim text
(cons 170 0); DIMALT
(cons 171 2) ;DIMALTD-controls the decimal places for units
(cons 172 0) ;DIMTOFL-forces a line inside extension lines
(cons 173 1); DIMSAH
(cons 174 0); DIMTIX
(cons 175 0); DIMSOXD
(cons 176 256); DIMCLRD
(cons 177 256); DIMCLRE
(cons 178 256); DIMCRRT
(cons 179 0); DIMADEC
(cons 270 2) ;DIMUNIT-sets the units format for all dims ;2 decimale ; 4architettonico
(cons 271 Decimal_Places) ;DIMDEC-sets the number of decimal places of primary units
(cons 272 Tolerance_Decimal_places); DIMTDEC
(cons 273 2) ;DIMALTU-sets the units for alt. units
(cons 275 0) ;DIMAUNIT-sets the angular format for angular dims
(cons 276 1); DIMFRAC
(cons 277 2); DIMLUNIT ;2 decimale ; 4architettonico
(cons 278 0); DIMDSEP
(cons 279 Text_Movement); DIMTMOVE
(cons 280 0) ;DIMJUST-controls the horizontal positioning of dim text
(cons 281 -1); DIMSD1
(cons 282 -1); DIMSD2
(cons 283 1); DIMTOLJ
(cons 284 3); DIMTZIN
(cons 285 1); DIMALTZ
(cons 286 0) ;DIMALTTZ-Toggles the suppression in tolerance values
;(cons 287 0); DIMFIT
;(cons 288 0); DIMUPT
;(cons 289 0); DIMATFIT
(cons 340 (tblobjname "style" "Estilo_Cotas")); DIMTXSTY
;(cons 341 (cdr (assoc 330 (entget (tblobjname "block" "."))))); DIMLDRBLK
;(cons 342 (cdr (assoc 330 (entget(tblobjname "block" "_Oblique"))))); DIMBLK
;(cons 343 (cdr (assoc 330 (entget(tblobjname "block" "_Oblique"))))); DIMBLK1
;(cons 344 (cdr (assoc 330 (entget(tblobjname "block" "_Oblique"))))); DIMBLK2
;(cons 371 -2); DIMLWD
;(cons 372 -2); DIMLWE
(entmake ds)
(command "_-dimstyle" "_restore" dim_name)
;(dimsave)
(princ)
(defun dimsave ()
(command "DIMSTYLE" "_R" "DIMTEST")
(setvar "DIMTXSTY" "Estilo_Cotas")
(command "DIMSTYLE" "_S" "DIMTEST" "Y")
