Copy _from automation
- Mute
- Permalink
- Report
Hi There,
I hope you could help me with this easy task. I am sure you will. It's an easy one.
As part of our design process, we copy very often the same item, along the same axis, but in different increments.
This is an easy task that can be achieved with the command Copy and then _from so you can input the increment distances.
We have our mouse set with macros for a range of commands and I would like to implement this into one of them but as it requires to first use "Copy", then select the base point, then the modifier "_from" and select again the reference point, It would require the use of two buttons of the mouse.
Is there any way of creating a shortcut for Copy+_From with one single command line so I can asing it to a macro in my mouse?
Thank you very much and best regards
