coordinates lisp draw the line instied of point please guide,,, regards
iftikhargulmrd
Message 1 of 11
iftikhargulmrd
;CONVERT GRAD TO RADIAN
(DEFUN GTR (a)
(* PI (/ a 200.0))
;CONVERT RADIAN TO GRAD
(DEFUN RTG (a)
(/ (* a 200.0) PI)
;CONVERTS RECTANGULAR COORDINATES (X,Y) TO POLAR COORDINATES (r,@)
(DEFUN AZDS (DE DN)
(SETQ X (SQRT (+ (EXPT DE 2) (EXPT DN 2))))
(SETQ Y (ATAN (/ DN DE)))
(DEFUN AAZZ (A)
(SETQ GH (* PI 2)
HG (/ PI 2)
X (+ (- GH A) HG)
X (IF (> X GH) (- X GH) X)
;CONVERTS POLAR COORDINATES (r,@) TO RECTANGULAR COORDINATES (X,Y)
(DEFUN DALTA (BE HD)
(SETQ X (* (SIN BE) HD))
(SETQ Y (* (COS BE) HD))
;AS POLAR FUNCTION
(DEFUN COO (PO BE HD)
(LIST (+ (* (SIN BE) HD) (NTH 0 PO))
(+ (* (COS BE) HD) (NTH 1 PO))
(defun c:txt()
(setvar "AUNITS" 2)
(setvar "ANGBASE" (/ PI 2))
(setvar "ANGDIR" 1)
(setq h (getdist "\nEnter height of text:")
GH (* PI 2)
HG (/ PI 2)
HA (GTR 100.0)
VA (GTR 200.0)
ds1 (* 6.0 H)
ds2 (* 9.0 H)
ds3 (* 1.2 H)
dsV (* 3.0 H)
DSN (/ DSV 2.0)
VA0 (GTR 0.0)
bs (getpoint "\nEnter Base point for table:")
no (getint "\nEnter point no.:")
b (getpoint "\nEnter start point:")
lm 0.0
bs1 (COO bs ha ds1)
bs2 (COO bs ha (+ ds1 H H ds2))
bs3 (COO bs ha (+ ds2 (* 20 H) ds3))
(command "layer" "n" "table" "c" "7" "table"
"n" "line" "c" "1" "line"
"n" "no" "c" "3" "no" ""
(setq f (open "d:\\Coordinates XYZ.txt" "w"))
(while b
(setq st (COO bs va (* dsV lm))
st1 (COO bs1 va (* dsV lm))
st2 (COO bs2 va (* dsV lm))
st3 (COO bs3 va (* dsV lm))
BH (COO B VA0 DSN)
(command "layer" "s" "table" "")
(command "text" st h (rtG ha) no)
(command "text" st1 h (rtG ha) (rtos (car b) 2 3))
(command "text" st2 h (rtG ha) (rtos (cadr b) 2 3))
(command "text" st3 h (rtG ha) (rtos (caddr b) 2 3))
(write-line (strcat (rtos no 2 3) " " (rtos (car b) 2 3) " " (rtos (cadr b) 2 3) " " (rtos (caddr b) 2 3) ) f)
;;; (write-line (rtos (cadr b) 2 3) f)
;;; (write-line (rtos (caddr b) 2 3) f)
(command "layer" "s" "no" "")
(command "text" bH h (rtG ha) no)
(SEtq lm (+ lm 1)
NO (+ NO 1)
c (getpoint "\nEnter next point:")
(command "layer" "s" "line" "")
(command "pline" B "w" "0.0" "0.0" c "")
(setq b c)
(close f)
(SETQ STL (COO ST (+ VA (/ HG 2)) (/ DSV 2)))
(SETQ STL1 (COO STL HA (* H 40)))
(COMMAND "LINE" STL STL1 "")
(COMMAND "ARRAY" STL "" "R" (FIX (+ 1 LM)) "" DSV)
(princ "\n < idtl > loaded:")
(princ)
Replies (10)
Message 2 of 11
CodeDing
@iftikhargulmrd ,
1) What is your question? Please explain.
2) Can you post an image of your work area BEFORE you run the command and AFTER you run it so we can see also?
3) Copy & Paste your command history after you run the command. Often times this will provide valuable feedback as to what is going wrong.
Best,
~DD
Message 3 of 11
iftikhargulmrd
instead to draw the line to mark nod
Message 4 of 11
Sea-Haven
A quick fix not tested
change
to
(command "point" b)
change (command "pline" B "w" "0.0" "0.0" c "") to (command "Point" c)
Message 5 of 11
dbhunia
Change as below...
(DEFUN GTR (a)
(* PI (/ a 200.0))
(DEFUN RTG (a)
(/ (* a 200.0) PI)
(DEFUN AZDS (DE DN)
(DEFUN AAZZ (A)
(SETQ GH (* PI 2)
HG (/ PI 2)
X (+ (- GH A) HG)
;AS POLAR FUNCTION
(defun c:txt()
(setvar "AUNITS" 2)
(setvar "ANGDIR" 1)
GH (* PI 2)
HG (/ PI 2)
HA (GTR 100.0)
VA (GTR 200.0)
ds1 (* 6.0 H)
ds2 (* 9.0 H)
ds3 (* 1.2 H)
dsV (* 3.0 H)
DSN (/ DSV 2.0)
VA0 (GTR 0.0)
lm 0.0
bs1 (COO bs ha ds1)
(command "layer" "s" "line" "");;; set the Layer as current.
(command "Point" b)
(while b
BH (COO B VA0 DSN)
(SEtq lm (+ lm 1)
NO (+ NO 1)
;(command "pline" B "w" "0.0" "0.0" c "")
(command "Point" c);;; @Sea-Haven also said this.
(setq b c)
(close f)
(princ)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 6 of 11
iftikhargulmrd
appreciate booth of you brothers,
but one issue first number is not mark the nod
Regards
Message 7 of 11
dbhunia
But it is working for me.....
Watch this....
Debashis Bhunia
Message 8 of 11
iftikhargulmrd
Sir can you please upload same lisp which you use
I think do mothing wrong
regrads
Message 9 of 11
Sea-Haven
Just me
(setvar 'clayer line)
Message 10 of 11
dbhunia
Just Your's....
@Sea-Haven  you can do that, but throughout the code @iftikhargulmrd 's approach is
So I just followed his way.......
Debashis Bhunia
Message 11 of 11
iftikhargulmrd
Thanks A LOT BOROTHER
