coordinate which appear more than once from other list in autolisp
I have a coordinate list and in a every time in a loop of polyline  its will check the coordinate which appear more than once from the list in autolisp
john.uhden
I presume that you want to "check" a coordinate only once, even if it is in a list more than once.
This may help to remove duplicates from a list:
  (defun @remdupes (Old fuzz / Item New)
    (while (setq Item (car Old))
      (setq Old (vl-remove-if '(lambda (x)(equal Item x fuzz))(cdr Old))
            New (cons Item New)
    (reverse New)
It will work with numbers and coordinates.  OMG, it even works with strings.
John F. Uhden
