Coordinate comparison
saitoib
saitoib
Thanks again for your help.
I considered the following Lisp to determine whether two coordinates are the same or not.
Is there a better way?
line 0,0 100,0
line 0,0 0,100
(defun c:test3 (/ id1 id2 pt1 pt2 ret )
	(setq id1 (car (entsel)))
  (setq id2 (car (entsel)))
  (setq pt1 (assoc 10 (entget id1)))
  (setq pt2 (assoc 10 (entget id2)))
  (setq ret (= pt1 pt2))
  (princ "\n= : ") (princ ret)
  (setq ret (eq pt1 pt2))
  (princ "\neq : ") (princ ret)
  (setq ret (_is_same pt1 pt2))
  (princ "\n_is_same : ") (princ ret) (princ)
(defun _is_same (p1 p2 / )
  (and (= (car p1) (car p2)) (= (cadr p1) (cadr p2)) (= (caddr p1) (caddr p2)))
Saitoib
ВeekeeCZ
When you compare real numbers - which are never exact - use EQUAL with reasonable fuzz (which could depend on the industry you're working in and units m vs mm).
(equal pt1 pt2 1e-8)
-didier-
Bonjour @saitoib
It is not necessary to compare each coordinates, it is possible to compare two lists in this way :
assuming p1 and p2 are two lists of points
(equal p1 p2)
Will return T which means that the two lists are identical.
Amicalement
Éternel débutant.. my site for learning : Programmer dans AutoCAD
DA
saitoib
@-didier-
gah
Isn't eq a short form of equal?
I guess eq and equal were two different things.
Thank you very much!
Saitoib
-didier-
Bonjour @saitoib
Allow me to direct you to the pages of my site, it is in French, but I think I will make an English version, while waiting ,translate online is possible, I do not have time for that.
LINK
Amicalement
DA
