Converting Splines to Flattened Bezier Curves
Background:
     I am using python to modify elements in large AutoCAD files. I want to make changes to entities without using the "sendCommand" function. The end resulting drawings cannot contain any splines, among other things. In order to accomplish this I am converting the splines to flattened Bezier Curves (PolyLine). Image 1 helps illustrate this idea.
Image 1: Flattened Bezier Curve, Source: https://pomax.github.io/bezierinfo/Image 1: Flattened Bezier Curve, Source: https://pomax.github.io/bezierinfo/
Problem:
   I succeeded in creating flattened Bezier Curves, although above degree 3, splines in AutoCAD no longer resemble Bezier Curves as seen below. Degree 3 Spline CV resembles flattened Bezier CurveDegree 3 Spline CV resembles flattened Bezier Curve
Degree 4 curve does not match flattened Bezier CurveDegree 4 curve does not match flattened Bezier CurveQuestion:
   How does AutoCAD define splines over degree 4? It appears that the AutoCAD spline is weighted, but when I ask for the weights of the spline i get the following error. Capture.PNG
Any help would be greatly appreciated
Thanks for reading
Moshe-A
Flakeh,
the SPLINEDIT command has an option 'convert to Polyline'
moshe
Yes, but like I mentioned, using "SendCommand" is not an option in this case.
Moshe-A
here is a lisp function to convert spline to polyline
can you send a command like this:
SendCommnad("(spline->pline entity)")
the obj argument can be VLA-OBJECT or ENAME
moshe
(defun spline->pline (obj / execmd ;| local function |;)
 (defun execmd (ename)
  (command "._splinedit" ename "p" "")
 ); execmd
 (cond
  ((eq (type obj) 'VLA-OBJECT)
   (execmd (vlax-vla-object->ename obj))
  ); case
  ((eq (type obj) 'ENAME)
   (execmd obj)
  ); case
  ( t
   (prompt "\nerror: invalid argument.")
  ); case
 ); cond
); spline->pline
I ended up answering my own question. The splines used in AutoCAD are B-splines. You can use the knots and control points along with the scipy.interpolate module in python to calculate sample points. Polyline approximation of a spline. The circles represent the control points calculatedPolyline approximation of a spline. The circles represent the control points calculatedOriginal spline, degree 3, 7 control pointsOriginal spline, degree 3, 7 control points
This is the python code i used to convert the splines into polylines.
It's useful because, like someone mentioned a couple times, there is a SPLINEDIT command to convert splines to polylines, but I prefer not to use "SendCommand". This code allows you to accomplish the same thing without using "SendCommand". The logic is all there so whomever finds this helpful can just transcribe it to LISP or VBA.
def my_B_spline(obj,resolution):
    knots=obj.knots
    points=obj.controlpoints
    degree=obj.degree
    mtx,numP=form_matrix(points)
    def N(i,p,u):
        if p==0:
            if knots[i]<=u<knots[i+1]:
                return 1
            else:
                return 0
        else:
            if not (knots[i+p]-knots[i])==0:
                eq1=(u-knots[i])/(knots[i+p]-knots[i])
            else:
                eq1=0
            if not (knots[i+p+1]-knots[i+1])==0:
                eq2=(knots[i+p+1]-u)/(knots[i+p+1]-knots[i+1])
            else:
                eq2=0
            return eq1*N(i,p-1,u)+eq2*N(i+1,p-1,u)
    output=mtx[0]
    for u in np.linspace(knots[0],knots[-1],num=resolution,endpoint=False)[1:]:
        nextPoint=np.array([0,0,0],dtype='float')
        print("new time called")
        for i in range(0,numP):
            nextPoint+=N(i,degree,u)*mtx[i]
        output=np.vstack([output,nextPoint])
    return np.vstack([output,mtx[-1]])
It takes a spline object and resolution(how many points you want to divide the spline into) and returns an array of sample points on the spline.
