convert text to multiline and reverse
eyal.ch
eyal.ch
Hi all,
I want to convert text to multiline text and also reverse.
thank you.
komondormrex
hey,
there is plenty of such text->mtext converting codes) you can easily find one. mine is in attachment.
you also can use express tools command "_txt2mtxt" for that purpose.
to convert otherwise use autocad command "_explode", which will normally explode mtext to text lines unless occasionally unicode characters are encountered.
eyal.ch
thank you @komondormrex ,
I found 2 lisps but they didn't work,
yours work fine,
thank you
