option for superscript and subscript in text
eyal.ch
eyal.ch
Hi all,
Can anyone help with lisp that does exactly as with the multiline text,
for example in text X2 - after selecting the number 2, I will click upper or lower and the number will be superscript or subscript, like this:
thank you
komondormrex
hey,
you may try to use unicode characters in text string for superscript or subscript digits if they are in font used.
Kent1Cooper
Since MTEXT can do this already, is there some reason that you need it to be plain TEXT?
Kent Cooper, AIA
eyal.ch
hi @Kent1Cooper ,
because I have a lot of files that are already made with text, and I want to change them.
Kent1Cooper
And how is subscript/superscript currently done in those existing Text objects?  With separate Text objects for the lowered/raised elements?  With fonts using custom-defined characters?  They're just not sub/super at all?  Something else?  In other words, given a routine to do what you want, what would you be selecting and how would it need to be changed?
Kent Cooper, AIA
