Convert mode doesn't work when making a block
3wood
Advisor Advisor
Message 1 of 10
3wood
Hi all,
I tried to make a block with command -block in a lisp file, but it doesn't convert selected objects into the new block. It seems "Retain" and "Convert" mode doesn't work in -block command:
(command "-block" "test" "mode" "convert" "0,0" "last" "")
Thanks for the help.
Replies (9)
Message 2 of 10
paullimapa
Message 3 of 10
Moshe-A
@3wood  hi,
Yes you are right, to me it looks like a 'bug', an option they forgot to add when it is called from (command) function 😂
Moshe
Message 4 of 10
hmsilva
@3wood wrote:
Hi all,
Try
(command "block" "test123" "mode" "convert" "0,0" "last" "")
;or
(command "block" "test456" "mode" "retain" "0,0" "last" "")
;or
(command "block" "test789" "mode" "delete" "0,0" "last" "")
Hope this helps,
Henrique
Message 5 of 10
Moshe-A
@hmsilva ,
to make it clear, the block is created but it's not inserted (as it does when you do it manually) i am testing it on R2022
Message 6 of 10
hmsilva
@Moshe-A wrote:
@hmsilva ,
@Moshe-A i did test in R2021, in R2022 didn't work as expected.
In R2022 and "2023 this work as expected...
(defun c:demo ( / s1 s2 s3)
    (if	(setq s1 (ssget))
      (progn
	(initcommandversion)
	(command "-block" "test123" "mode" "convert" "0,0" s1 ""))
    (if	(setq s2 (ssget))
      (progn
	(command "-block" "test456" "mode" "retain" "0,0" s2 ""))
    (if	(setq s3 (ssget))
      (progn
	(command "-block" "test789" "mode" "delete" "0,0" s3 ""))
    (princ)
it's weird...
Edit: (initcommandversion 2) works in R 21, 22 and 23
Hope this helps,
Henrique
Message 7 of 10
Moshe-A
@hmsilva  OK
Never cross my mind BLOCK is governed by (initcommandversion)  🤔
Message 8 of 10
3wood
(initcommandversion) works!
Thank you very much.
Message 9 of 10
paullimapa
So just need to do a test for the acad version.
If older than 2022, then use custom lisp, else use (initcommandversion)
(if(< (atoi(getvar"acadver"))24)
 (progn
 ...use custom lisp
 (progn
) ; if
Paul Li
IT Specialist
@The Office
Message 10 of 10
hmsilva
You're welcome, @3wood
Glad I could help
Henrique
