Retrieve value of Desktop Connector Cache location for each user as Variable
KPerison
KPerison
I have a .CSV file that manages our title block attributes. A script file that runs LISP routing that reads those values, updates the title blocks, then plots the dwgs and places them into a defined folder location.
I had previously written the code to work with BIM30/ACC when the default location for the cache was your C:\.
C:\Users\username\ACCDocs\
With recent updates you have the option of changing your default "Workspace" location drive , root folder, etc
Now that the root location to that local cache is variable my routine will not work unless they left their install in the default location.
Is there a way to extract the DTC cache path as a variable?
This is an example portion of the code I have atm.
(load (strcat "C:\\Users\\" (getenv "username") "\\ACCDocs\\......blahblah......\\UpdateTBAttributes.lsp"))
If for example someone modifies their DTC workspace to say D drive and a Subfolder that path would be like this:
D:\Users\username\DC\ACCDocs\.....blahblah.....\UpdateTBAttributes.lsp
How would you extract the red text as a variable??
Pls/Thx.
marko_ribar
(setq path (strcat (getenv "HOMEDRIVE") (getenv "HOMEPATH")))
"C:\\Users\\Korisnik"
Marko Ribar, d.i.a. (graduated engineer of architecture)
KPerison
Thanks, I've used those variables before as well, but....
When I enter that code it returns:
"C:\\Users\\kperison"
The workspace drive and folder I have set is:
D:\Users\kperison\DC
So, it is not pulling the DTC workspace location. Just the Windows user settings.
trevor.bird.au
Hi Kelly,
Please try the following which is based on Desktop Connector version 16.2.1.2016 being installed.
(vl-registry-read "HKEY_CURRENT_USER\\SOFTWARE\\Autodesk\\Autodesk Drive" "Workspaces")
This will return a list e.g. (7 "%userprofile%\DC\ACCDocs")
From Autodesk which I assume is the default workspace location:
Your new v16 local workspace location will be %userprofile%\DC\ACCDocs
The registry key type is 'REG_MULTI_SZ' which indicates that a list of folders can be set however I haven't seen any Autodesk documentation that explains why this is so.
(cadr (vl-registry-read "HKEY_CURRENT_USER\\SOFTWARE\\Autodesk\\Autodesk Drive" "Workspaces"))
This will return the folder e.g. "%userprofile%\DC\ACCDocs"
Trevor
KPerison
Fantastic. That's exactly it. Thank you so much.
KPerison
Just a quick follow-up for anyone wandering onto the scene afterward.
Seems the installation of Desktop Connector is a wee-bit random.  I'll explain.
When the installation occurs, 2 drives are installed ACCDocs (Docs) and ADrive (Autodesk Drive).
In the registry, those workspace locations are recorded under a Multi-String Reg variable thus both path locations are recorded in the same variable.
What I've discovered is that depending on the Time of day and barometric pressure those 2 paths can swap order in the REG variable when installing.
How do I know this - working on projects btwn 15.8 and 16.3 = Constant uninstall/Install cycles. Fun!
So, if you are trying to pull the ACCDocs workspace path you may need to re-order the path listing in the variable.
Once I re-ordered the path listing my routines started working once again.
Edited the registry and moved the ACCDocs path to the top of the list.
