Connect center of circles by 3d Poly
borislav_k_atanasov
Observer Observer
borislav_k_atanasov
Observer
Observer
Hi all,
I'm after a LISP that will connect the center of circles with 3D poly line.
I found THIS solution by DannyNL, but it connects it in a rather chaotic manner:result - off.jpg
What I actually need is this:
It stars looking on the X-axis going to +  and only if there are no more circles it goes up&right, then starts going on the X-axis towards 0 and so on.
wispoxy
Ehhh... Trying to think of it from a mathematical standpoint. If nil on X then Y- to obj. 🤔
marko_ribar
You meight be looking for greedy algorithm... So there is one implemented in TSP (Travelling Salesman Problem) posted here in download section... You have to strip it from *.arx processing or just use grid option when you start routine... But all in all, I doubt it'll go X+X+X+...X ; -X-X-X-...-X... It'll search for closest point or center of circle in every step from starting point to end one and at the end it'll make closed polyline that don't make crossings... Link for download is here : https://www.cadtutor.net/forum/files/file/42-tspzip-travelling-salesman-problem-autolisp/
Marko Ribar, d.i.a. (graduated engineer of architecture)
komondormrex
hey there,
check the following
(defun c:meander (/ circle_sset center_list y_coordinate_list unique_y_list 3dpoly_vertices_list)
	(if (setq circle_sset (ssget '((0 . "circle"))))
		(progn
			(setq center_list (mapcar '(lambda (circle) (vlax-get circle 'center)) (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex circle_sset)))))
				  y_coordinate_list (vl-sort (mapcar 'cadr center_list) '<)
				  y_fuzz 1
			(foreach _y y_coordinate_list (if (not (vl-some '(lambda (y_unique) (equal _y y_unique y_fuzz)) unique_y_list)) (setq unique_y_list (append unique_y_list (list _y)))))
			(setq center_list (mapcar '(lambda (_y) (vl-remove-if-not '(lambda (center) (equal (cadr center) _y y_fuzz)) center_list)) unique_y_list)
				  center_list (mapcar '(lambda (y_sublist) (if (zerop (rem (vl-position y_sublist center_list) 2))
																(vl-sort y_sublist '(lambda (center_1 center_2) (< (car center_1) (car center_2))))
																(vl-sort y_sublist '(lambda (center_1 center_2) (> (car center_1) (car center_2))))
									   center_list
				  3dpoly_vertices_list (apply 'append (apply 'append center_list))
			(vla-add3dpoly (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
			  	   		   (vlax-safearray-fill (vlax-make-safearray vlax-vbdouble (cons 1 (length 3dpoly_vertices_list)))
	(princ)
Sea-Haven
Removed solution for 2d poly posted.
borislav_k_atanasov
Observer
Observer
Works almost perfect! really appreciate it!
I have encounter an issue:
I have planes that are arranged in a 3d shape and the dots are placed flat on each plane. When I try to flatten the 3d planes into 2d projection the LISP does not select the circles.
Also, can I ask you to help me to add a restriction of the line between the center of the circles to be not more than 250mm?
Appreciate your help!
marko_ribar
@komondormrex
Can't you see that your codes are written in manner that your lines go to much right, so it's very difficult to follow what you've written... If you don't mind, I'll post your code prittyfied manually by me, so that everyone is able to see it easy, at least little better than your original version...
(defun c:meander ( / circle_sset center_list y_coordinate_list unique_y_list 3dpoly_vertices_list )
  (or (not (vl-catch-all-error-p (vl-catch-all-apply 'vlax-get-acad-object nil))) (vl-load-com))
    (progn
      (setq center_list (mapcar '(lambda ( circle ) (vlax-get circle 'center)) (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex circle_sset)))))
            y_fuzz 1
        (if (not (vl-some '(lambda ( y_unique ) (equal _y y_unique y_fuzz)) unique_y_list)) (setq unique_y_list (append unique_y_list (list _y))))
      (setq center_list (mapcar '(lambda ( _y ) (vl-remove-if-not '(lambda ( center ) (equal (cadr center) _y y_fuzz)) center_list)) unique_y_list)
           center_list
             (mapcar
              '(lambda ( y_sublist )
                   (vl-sort y_sublist '(lambda ( center_1 center_2 ) (< (car center_1) (car center_2))))
                   (vl-sort y_sublist '(lambda ( center_1 center_2 ) (> (car center_1) (car center_2))))
               center_list
  (princ)
