Dimaligned command produces "no function definition: nil" error upon completion
DerekX9SQ2
Message 1 of 18
DerekX9SQ2
Hi!
I've written an AutoLISP script that helps me with some of my day-to-day activities. I'm currently running into a problem while trying to create DIMALIGNED objects.
Here's the line:
(command "dimaligned" (car (cdr (nth 0 actMlist))) (car (cdr (nth 1 actMlist))) "t" (strcat "RISE: " (rtos rise 2 2) "' \n" "RUN: " (rtos run 2 4) "' \n SLOPE: " slope "%") (car (cdr (nth 0 actMlist))))
This line executes with no problems. It creates an Aligned Dimension, changes the text as desired, and places it where I want it. However, no matter what code I put after this line, it tries to execute it as a function. I've tried replacing the last point with a pause and finishing the command with ("") at the end and  (command) on the next line to no avail. Any help here would be great!
Here's a screenshot. I'll be happy to provide more information if needed.
Replies (17)
Message 2 of 18
Sea-Haven
I remember  "exit" not "" I seem to remember had to do with some code related to dimensions.
(command "DIM" "align" pt1 pt4 pt3 "" "exit")
Message 3 of 18
DerekX9SQ2
When I tried exit it said:
(command "dimaligned" (getpoint)(getpoint)(getpoint) "_exit")
Command: exit Unknown command "EXIT".  Press F1 for help.
Command: nil
Message 4 of 18
DerekX9SQ2
I just tried finishing the line with:
so that it looks like :
(command "dimaligned" (car (cdr (nth 0 actMlist))) (car (cdr (nth 1 actMlist))) "t" (strcat "RISE: " (rtos rise 2 2) "' \n" "RUN: " (rtos run 2 4) "' \n SLOPE: " slope "%") (car (cdr (nth 0 actMlist))) `"")
and when it finishes executing that line, it tries to re-run the function that I'm currently in.
To clarify, I type "ds1" to start the command, it runs until the error, and then it tried to run "ds1" again.
Here's a picture of the error log,
Message 5 of 18
wispoxy
You can't assign EXIT. It's already an autocad default.
Message 6 of 18
wispoxy
Why not just:
(defun c:MyDimAligned ()
  (setq actMlist '((1 2) (3 4))) ; Replace with your actual point coordinates
  (setq rise 5.67) ; Replace with your actual rise value
  (setq run 3.45) ; Replace with your actual run value
  (setq slope 12.34) ; Replace with your actual slope value
  (setq output-string
        (strcat
         "RISE: " (rtos rise 2 2) "'\n"
         "RUN: " (rtos run 2 4) "'\n"
         "SLOPE: " (rtos slope 2 2) "%"))
  (princ output-string)
Message 7 of 18
DerekX9SQ2
I want to use a dimaligned because it's a standard I'm tied to with my employer. At this point I'm honestly just really confused at what's happening to throw this error. It seems like the autoLISP interpreter doesn't exit the dimaligned command properly.
Making it even more perplexing, it will execute lines of code AFTER the dimaligend command UNTIL it exits the current function, here's what I mean:
(defun riseRunSlope ()
	(setq rise (abs (- (car (nth 0 actMlist)) (car (nth 1 actMlist)))))
	(setq slope (rtos (* 100 (/ rise run)) 2 2))
	(setq plineFlag nil)
	(princ "\n hi \n")
	(princ "\n WHY?!!?!?!?!?! \n")
	(princ (+ 10 15))
	(princ "Still executing")
Notice that it runs all the way to the last print function and then tries to execute the text inside of the last print as a function.
Message 8 of 18
wispoxy
Try (exit) to end function
Message 9 of 18
DerekX9SQ2
That appears to exit the entire LISP function and not just the function at the level the code is executed.
Message 10 of 18
marko_ribar
You don't have assigned "run" variable...
Check your code before posting...
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 11 of 18
DerekX9SQ2
I just posted a snippet as the code is 200+ lines. Here's the file
Message 12 of 18
marko_ribar
Please, have a look how I used DIMALIGNED command... It accepts 3 points and that's all - there should be no "" at the end or anywhere inbetween specified points...
Here is the link : https://forums.augi.com/showthread.php?168619-Automatically-dimension-all-sides-and-angles-of-select...
Message 13 of 18
Kent1Cooper
Is there any chance you're working with a redefined DIMALIGNED command?  What if you force use of the native command with the period prefix?
(command ".dimaligned" ...)
Kent Cooper, AIA
Message 14 of 18
DerekX9SQ2
I got this to work! Thank you very much!!!
Message 15 of 18
DerekX9SQ2
I wasn't able to get this to work. I fixed it by using (vla-adddimaligned)
Message 16 of 18
Sea-Haven
I tried this in my Bricscad V20 and it worked.
(command "dimaligned" (getpoint "\nP1")(getpoint "\nP2")(getpoint "\nP3") )
Message 17 of 18
DerekX9SQ2
I found and fixed the error at the end of the day yesterday! I was calling (progn) inside an (if) condition. That's why it kept trying to execute the last line of the function.
My code looked like this:
(if (= a b)
          (progn
               (vla-adddimaligned pt1 pt2 pt1)
               (setq var 1)
     ;else
when it needed to look like this:
(if (= a b)
     (progn
          (setq var 1)
     ;else
Message 18 of 18
Sea-Haven
You don't need a else. Sometimes I add an else or true false so can see what has happened.
(if (= a b)
     (progn
          (setq var 1)
(if (= a b)
     (progn
          (setq var 1)
     (princ "\nnot =")
