Select folder containing dxf and save as dwg
blandb
Mentor Mentor
Message 1 of 21
blandb
I have a company that has folders of dxf files, and they want me to open each dxf and save as dwg. I have the save options set to 2000 format, so I just open all the dxf's in the folder and then do a Zoom Extents > Save > Close....rinse and repeat for the remainder of the drawings open.
Is there a lisp routine that can be done to accomplish this? Select a folder, save the dxf's as the same name just in a dwg format into the same folder the dxf files are?
Thanks in advance
Autodesk Certified Professional
Replies (20)
Message 2 of 21
paullimapa
check out the solutions in this thread:
https://www.cadtutor.net/forum/topic/78909-batch-convert-dxf-to-dwg/
Paul Li
IT Specialist
@The Office
Message 3 of 21
ec-cad
Paulli,
Went to the link below: - cadtutor.net...
Got a screen from Microsoft about a Trojan ?
What's up with that ?
ECCAD
Message 4 of 21
pendean
Community Legend
Community Legend
@ec-cad wrote:
Paulli,
ECCAD
Nothing like that here is any of my webbrowsers to that link or any other CADTUTOR page
Message 5 of 21
ec-cad
Blandb,
You may want to try this one. Open a junk file, and appload. Pick the folder that contains the DXF files. Seems to work for me. Hit escape / quit when the process is done.
Cheers
ECCAD
Message 6 of 21
ec-cad
Hmmm,
That's not the front end screen I saw, had a single dialog box, with "Continue".
Probably a Chrome issue locally. I'll see if I can duplicate it.
Bob
Message 7 of 21
ec-cad
Yes, is OK now. I just went there. May be an issue with my local machine.
My appologies.
Bob
Message 8 of 21
blandb
I didn't have any issues going to the site, but after scanning through and clicking around, I found something is the appstore: https://apps.autodesk.com/ACD/en/Detail/Index?id=3434696327413675915
Has anyone tried this?
Message 9 of 21
paullimapa
I've not tried this but looks promising if you're into exploring/installing new apps.
The only caveat seems to be this:
Paul Li
IT Specialist
@The Office
Message 10 of 21
blandb
@ec-cad
Thanks, I'll look into it.
Message 11 of 21
blandb
@paullimapa
That is fine with me lol, I'm generating these out of Inventor.
Message 12 of 21
ec-cad
Blandb,
If your post implies that you 'need' a .scr file, rather than a .lsp file (maybe for AcadLT earlier version ?), then
attached probably won't work for you. If you can run Lisp, it will work fine.
ECCAD
Message 13 of 21
paullimapa
Since you're exploring, I copied, tested & modified the code from the link I provided in my original reply.
This does require Express Tools.
Paul Li
IT Specialist
@The Office
Message 14 of 21
blandb
Sorry, just getting time to come back to this. I tried the app store app and I couldn't get it to work with ACADM 2024. I had reached out to their support email and I have NEVER received a response back. Multiple emails and nothing. soo.... Just an FYI
Message 15 of 21
baksconstructor
No problem, use this -  AutoImportCAD
Message 16 of 21
paullimapa
I'm confused...I don't recall suggesting for you to try the app store app. Did you try the lisp code I attached in my previous reply?
Paul Li
IT Specialist
@The Office
Message 17 of 21
komondormrex
is it critical to zoom extents newly written dwg?
Message 18 of 21
blandb
I never said you did, but early on in the post, I had mentioned this app store program. I was just giving info back about how their customer service was non-existent.
Message 19 of 21
paullimapa
Got it.  But again try the lisp routine I posted and see if that works out for you.
Paul Li
IT Specialist
@The Office
Message 20 of 21
blandb
Thanks, I will. I just have not had a chance to get to it as of yet.
