Concatenate strings
Concatenate strings
gcsjlewis
Concatenate strings
gcsjlewis
Using Autocad Electrical 2020, I have 4 variables (DESCA, DESCB, DESCC & DESCD), they may be nil, or may have a value.  If they have a value I need to concatenate these with a "_" in-between.  Without a bunch of "if" statements, what's the best way to do this?
MunteanStefan
(setq l (vl-remove nil (list DESCA DESCB DESCC DESCD))
      str (car l)
(foreach x (cdr l) (setq str (strcat str "_" x)))
Kent1Cooper
[Never mind -- Message 2 is much better than my thoughts.]
Kent Cooper, AIA
john.uhden
Actually, we should check if any of the variables is not a string, not just nil...
(defun string-p (var)(= (type var) 'STR))
(setq l (vl-remove-if-not 'string-p (list DESCA DESCB DESCC DESCD))
      str (car l)
 OR, we could force all the variables to be strings
(setq l (mapcar 'vl-princ-to-string (list desca descb descc descd)))
John F. Uhden
hak_vz
@gcsjlewisI will rephrase your request, and make it more generic solution. Here is a function that concatenates elements of the list of arbitrary length with some concatenation symbol (string), and removes all elements of the list that equal nil. If all elements of the list are nil it will return string " " to suppress potential error if function is joined with other string dealing function.
Usage: (cancan (list DESCA DESCB DESCC DESCD)  "-")
(defun cancan (lst csym / i j str lst mklist)
(defun mklist (obj)(if (listp obj)obj(list obj)))
	(cond
		((= (type csym) 'STR)
			(setq
				i -1
				str ""
				lst (vl-remove nil (mklist lst))
			(cond ((and lst)
			(setq lst (mapcar 'vl-princ-to-string lst) j (- (length lst)1))
			(while (< (setq i (1+ i)) j)(setq str (strcat str (nth i lst)  csym)))
			(strcat str (last lst)))
			(T " ")
		(T (princ "\nConcatenation symbol is not a string!")(princ))
Miljenko Hatlak
