Command Repeats with Unknown Command
J_Monday
J_Monday
 I having a hard time implementing my search results to my issue. It seems like a common mistake, but I cannot understand where to fix the issue. I've tried removing any possible additional "" and tried replacing the hyphen before the command with a period or underscore. The same result happens.
The command works as needed. After the routine finishes, the command echo's with an "unknown command". See attached image please.  Thank you for the advise.
;.... Xref Delete 2017 FBC notes & Details and Loads 2020 FBC....
(defun C:trump2020 ()
(setvar "cmdecho" 0)
(command "-xref" "Detach" "2018 STANDARD DETAILS" "" "" "")
(command "-xref" "Attach" "2020-StandardDetails" "1980,0" "" "" "")
(command "draworder" "Last" "" "Back" "")
(command "-xref" "Detach" "2018-NOTES PAGE" "" "" "")
(command "-xref" "Attach" "2020-NotesPage" "1500,0" "" "" "")
(command "-xref" "Unload" "WindowProtectionSystem" "" "" "")
(setvar "cmdecho" 1)
(princ)
cadffm
Start with the first (command statement.
Type in your commandline
-xref<enter>
Look what Acad ask for,
Type in detach<enter>
and so on.
This way you will see the problem.
I don't think -XREF need more input than the detach option and reference name, or?
Sebastian
J_Monday
Got it. Thank you. I had way too many "" at the end of the -xref>detach portion. Below is the final version without issues.
(command "-xref" "Detach" "2018 STANDARD DETAILS")
(command "draworder" "Last" "" "Back")
(command "-xref" "Detach" "2018-NOTES PAGE")
(command "-xref" "Unload" "WindowProtectionSystem")
(princ)
