Visual Studio Code update stopped the Autolisp extension from working.
Someone besides me has the problem, after my vscode updating the Autolisp extension just stopped working. I try to run, choose the file and nothing happens.
The error still continues !!
I restored my computer to see if it worked but to no avail, but a new error has now appeared.
Sea-Haven
Contact Autodesk for comment.
pauls
This error has got me stuck too.  When I start the debugger I get a dialog asking me to install a common lisp extension.  Then the search shows me the autolisp extension I already have installed.
Sea-Haven
No idea dont use VS doubtful that I will, been doing coding other ways for to many years now, recommend Notepad++ plus its run time extension so can run code you have created in Notepad++.
diagodose2009
Hc90a11111111111.jpgYou can search the error/s inside the defunCrasher, only if
you extend yourLisp to yourLisp_jc10aro.lsp
You need to compile your Lisp to DebugVersion in Real-Time on Execute Lisp.(not bypas with Vlisp)
