Concatenate Multiple Block Attributes to an unique Block Attribute
jtm2020hyo
jtm2020hyo
Is there any method to select multiple blocks with AttDef's name "Att1", then call any function to create a concatenation of all AttDef's Att1 to another selected block with AttDef "Att2"
then the result should be:
Att2: "Block1-Att1-Value" & "Block2-Att1-Value" & "Block3-Att1-Value" & "Block4-Att1-Value"
... and what are the attribute values to do not repeat same values?
Sea-Haven
It can be done adding attributes and putting answer into another attribute.
The question is do you want to change a block attribute value and reflect the changes in block1, it is complicated you can not use copy say a block all that does is give 1 answer. When you add a block and want it to read another blocks att automatically and update it must re-read the id of the attributes and use those in a field which is adding the attribute values.
As an example block1 5 times, blocks 2 3 & 4 also 5 times so need to redo for all blocks involved. Every attribute has a different ID needed if using fields.
So the simplest it could be done
Pick block1 att
Pick block2 att
Pick block3 att
Pick block4 att
Update block1 att.
jtm2020hyo
Yes, I am thinking in use Fields Formula/Diesel/Expression/Anything, but there I did not found samples to start with
jtm2020hyo
Is possible merge all attributes attdef1 at attdef2 then filter repeated values in an attdef3 with any expression?
Sea-Haven
This is a block with 4 atts and it adds the 1st 3 attributes, and puts the answer into the 4th attribute.
(defun c:test ( / obj lst x )
(setq oldatt (getvar 'attdia))
(setvar 'attdia 0)
(command "-insert" "Blkname" (getpoint "\npick point") 1 1 0 (getstring "\nEnter Att1 ") (getstring "\nEnter Att2 ") (getstring "\nEnter Att3 ") "-")
(setq obj (vlax-ename->vla-object (entlast)))
(setq lst '())
(foreach att (vlax-invoke obj 'getattributes)
(princ  "\n")
(setq lst (cons  (strcat "%<\\AcObjProp Object(%<\\_ObjId "
(vlax-invoke-method (vla-get-Utility  (vla-get-activedocument (vlax-get-acad-object))) 'GetObjectIdString att :vlax-false)
">%).Textstring>%"
 ) lst ))
(setq str nil)
(setq x (length lst))
(setq str (strcat "%<\\AcExpr "
(nth (setq  x (- x 1)) lst) " + "
(nth (setq  x (- x 1)) lst) ">%"
(setq x 1 y 4)
(foreach att(vlax-invoke obj 'getattributes)
(if (= x y)
(Vla-put-textstring att str)
(setq x (+ x 1))
(setvar 'attdia oldatt)
(princ)
(c:test)
