I've slightly mod. it and made it prittier... Untested though... You should check profile strings you supply to (vla-put-activeprofile) function; perhaps \\ are needed instead of single \...
;;; rec_echelle
;;; routine de setup plan rochon infrastructel (écehelle - ltscale - dimstyle - textstyle)
;;; en lien avec rec_echelle.dcl
;;; version 2021-10-31
;;; créé par Martin Duval
(defun c:rec_profile nil
(vl-load-com)
(cond
( (= INFO 1)
(vla-put-ActiveProfile (vla-get-Profiles (vla-get-Preferences (vlax-get-acad-object))) "AutoCAD MEP \(US Metric\)")
( (= INFO 2)
(vla-put-ActiveProfile (vla-get-Profiles (vla-get-Preferences (vlax-get-acad-object))) "AutoCAD MEP \(US Imperial\)")
(defun c:rec_echelle ( / dcl_id w h LT userclick )
(setq dcl_id (load_dialog "C:/Users/mduval/OneDrive - Rochon Experts Conseils inc/_normes_REC/rec_echelle.dcl"))
(if (not (new_dialog "rec_echelle" dcl_id));not
(exit)
);if
(setq w (dimx_tile "im")
h (dimy_tile "im")
);setq
(start_image "im")
(slide_image 0 0 w h "C:/Users/mduval/OneDrive - Rochon Experts Conseils inc/_normes_REC/logo_rochon.sld")
;(fill_image 0 0 w h 5)
(end_image)
(action_tile "1M" "(setq INFO 1)")
(action_tile "0i" "(setq INFO 2)")
(action_tile "1000" "(setq LT 8000)")
(action_tile "750" "(setq LT 6000)")
(action_tile "500" "(setq LT 4000)")
(action_tile "400" "(setq LT 3200)")
(action_tile "300" "(setq LT 2400)")
(action_tile "250" "(setq LT 2000)")
(action_tile "200" "(setq LT 1600)")
(action_tile "150" "(setq LT 1200)")
(action_tile "125" "(setq LT 1000)")
(action_tile "100" "(setq LT 800)")
(action_tile "75" "(setq LT 600)")
(action_tile "50" "(setq LT 400)")
(action_tile "25" "(setq LT 200)")
(action_tile "10" "(setq LT 80)")
(action_tile "5" "(setq LT 40)")
(action_tile "1" "(setq LT 8)")
(action_tile "768i" "(setq LT 241.92)")
(action_tile "384i" "(setq LT 120.96)")
(action_tile "192i" "(setq LT 60.48)")
(action_tile "96i" "(setq LT 30.24)")
(action_tile "64i" "(setq LT 20.16)")
(action_tile "48i" "(setq LT 15.12)")
(action_tile "32i" "(setq LT 10.08)")
(action_tile "24i" "(setq LT 7.56)")
(action_tile "19.2i" "(setq LT 6.048)")
(action_tile "16i" "(setq LT 5.04)")
(action_tile "12i" "(setq LT 3.78)")
(action_tile "1i" "(setq LT 0.315)")
(action_tile
"cancel"
"(done_dialog) (setq userclick nil)"
);action_tile
(action_tile
"accept"
"(done_dialog) (setq userclick T)"
);action tile
(start_dialog)
(unload_dialog dcl_id)
(command "_.-dimstyle" "_r" "Annotative_REC")
(command "_.-dimstyle" "_r" "Annotative_REC-met")
(command "_.textstyle" "Annotative")
(command "_.ltscale" LT "")
(c:rec_profile)
(setq CANNOSCALE LT)
(cond
( (= LT 8000) (setvar "CANNOSCALE" "1:1000") )
( (= LT 6000) (setvar "CANNOSCALE" "1:750") )
( (= LT 4000) (setvar "CANNOSCALE" "1:500") )
( (= LT 2400) (setvar "CANNOSCALE" "1:300") )
( (= LT 3200) (setvar "CANNOSCALE" "1:400") )
( (= LT 2000) (setvar "CANNOSCALE" "1:250") )
( (= LT 1600) (setvar "CANNOSCALE" "1:200") )
( (= LT 1200) (setvar "CANNOSCALE" "1:150") )
( (= LT 1000) (setvar "CANNOSCALE" "1:125") )
( (= LT 800) (setvar "CANNOSCALE" "1:100") )
( (= LT 600) (setvar "CANNOSCALE" "1:75") )
( (= LT 400) (setvar "CANNOSCALE" "1:50") )
( (= LT 200) (setvar "CANNOSCALE" "1:25") )
( (= LT 80) (setvar "CANNOSCALE" "1:10") )
( (= LT 40) (setvar "CANNOSCALE" "1:5") )
( (= LT (setvar "CANNOSCALE" "1:1") )
( (= LT 241.92) (setvar "CANNOSCALE" "1/64\" = 1'-0\"") )
( (= LT 120.96) (setvar "CANNOSCALE" "1/32\" = 1'-0\"") )
( (= LT 60.48) (setvar "CANNOSCALE" "1/16\" = 1'-0\"") )
( (= LT 30.24) (setvar "CANNOSCALE" "1/8\" = 1'-0\"") )
( (= LT 20.16) (setvar "CANNOSCALE" "3/16\" = 1'-0\"") )
( (= LT 15.12) (setvar "CANNOSCALE" "1/4\" = 1'-0\"") )
( (= LT 10.08) (setvar "CANNOSCALE" "3/8\" = 1'-0\"") )
( (= LT 7.56) (setvar "CANNOSCALE" "1/2\" = 1'-0\"") )
( (= LT 6.048) (setvar "CANNOSCALE" "5/8\" = 1'-0\"") )
( (= LT 5.04) (setvar "CANNOSCALE" "3/4\" = 1'-0\"") )
( (= LT 3.78) (setvar "CANNOSCALE" "1\" = 1'-0\"") )
( (= LT 0.315) (setvar "CANNOSCALE" "1:1") )
(prompt "\nVariable INFO is global... To use it type REC_PROFILE at command prompt... To clear memory, type (setq INFO nil), or if you want to change value of INFO, restart main routine - type REC_ECHELLE at command prompt...")
(princ "\n")
(princ userclick)
(princ)
rec_echelle : dialog { //dialog name
label = "Echelle principale" ; //give it a label
: row { //define row
//// INFO SYSTEM UNITE
: boxed_radio_column { //define radio column
label = "systeme d'unite" ; //give it a label
: radio_button { //define radion button
key = "1M" ; //give it a name
label = "metrique" ; //give it a label
} //*end definition
} //*end radio column
key = "0i" ; //give it a name
label = "imperial" ; //give it a label
} //*end definition
} //end row
//// colonne métrique
label = "Metrique" ; //give it a label
key = "1000" ; //give it a name
label = "1:1000" ; //give it a label
} //end definition
key = "750" ; //give it a name
label = "1:750" ; //give it a label
} //end definition
key = "500" ; //give it a name
label = "1:500" ; //give it a label
} //end definition
key = "400" ; //give it a name
label = "1:400" ; //give it a label
} //end definition
key = "300" ; //give it a name
label = "1:300" ; //give it a label
} //end definition
key = "250" ; //give it a name
label = "1:250" ; //give it a label
} //end definition
key = "150" ; //give it a name
label = "1:150" ; //give it a label
} //end definition
key = "125" ; //give it a name
label = "1:125" ; //give it a label
} //end definition
key = "100" ; //give it a name
label = "1:100" ; //give it a label
} //end definition
key = "75" ; //give it a name
label = "1:75" ; //give it a label
} //end definition
key = "50" ; //give it a name
label = "1:50" ; //give it a label
} //end definition
key = "25" ; //give it a name
label = "1:25" ; //give it a label
} //end definition
key = "20" ; //give it a name
label = "1:20" ; //give it a label
} //end definition
key = "10" ; //give it a name
label = "1:10" ; //give it a label
} //end definition
key = "5" ; //give it a name
label = "1:5" ; //give it a label
} //end definition
key = "1" ; //give it a name
label = "1:1" ; //give it a label
/// value = "1" ; //switch it on
} //end definition
} //end radio column
///// impérial
label = "Imperial" ; //give it a label
key = "768i" ; //give it a name
label = "1\/64\" = 1'-0\"" ; //give it a label
} //end definition
key = "384i" ; //give it a name
label = "1\/32\" = 1'-0\"" ; //give it a label
} //end definition
key = "192i" ; //give it a name
label = "1\/16\" = 1'-0\"" ; //give it a label
} //end definition
key = "96i" ; //give it a name
label = "1\/8\" = 1'-0\"" ; //give it a label
} //end definition
key = "64i" ; //give it a name
label = "3\/16\" = 1'-0\"" ; //give it a label
} //end definition
key = "48i" ; //give it a name
label = "1\/4\" = 1'-0\"" ; //give it a label
} //end definition
key = "32i" ; //give it a name
label = "3\/8\" = 1'-0\"" ; //give it a label
} //end definition
key = "24i" ; //give it a name
label = "1\/2\" = 1'-0\"" ; //give it a label
} //end definition
key = "19.2i" ; //give it a name
label = "5\/8\" = 1'-0\"" ; //give it a label
} //end definition
key = "16i" ; //give it a name
label = "3\/4\" = 1'-0\"" ; //give it a label
} //end definition
key = "12i" ; //give it a name
label = "1\" = 1'-0\"" ; //give it a label
} //end definition
key = "1i" ; //give it a name
label = "12\" = 1'-0\"" ; //give it a label
} //end definition
} //end row
ok_cancel ; //predifined OK/Cancel
: image { //define image tile
key = "im" ; //give it a name
height = 8.0 ; //and a height
width = 24.0 ; //and now a width
} //end image
: paragraph { //define paragraph
: text_part { //define text
label = "standard" ; //give it some text
} //end text
: text_part { //define more text
label = "Rochon Infrastructel 2021" ; //some more text
} //end text
} //end paragraph
} //end row
} //end dialog
HTH.
Marko Ribar, d.i.a. (graduated engineer of architecture)
