Define 2nd list element values from 1st list elements
avinash00002002
Message 1 of 13
avinash00002002
Hi!
I have a list that I want to create a new list based on 1st list.
my list is:
(70.0 132.0 70.0 132.0 70.0 70.0 150.0 70.0 150.0 70.0 70.0 70.0 70.0 130.0 70.0 150.0 70.0 130.0 70.0 70.0 150.0 70.0 70.0 132.0 70.0 132.0 70.0 132.0)
I have derived that there is a 4 type of value in above list. like (70.0 130.0 132.0 150.0)  so,
I want to set the value in second list,
if 70.0 then (/ 19.0 4.0)
if  130.0 then (/ 19.0 3.0)
if 132,0 then (/ 19.0 2.0)
if 150,0 then 19.0
how to do? any help!
Replies (12)
Message 2 of 13
marko_ribar
(mapcar '(lambda ( x ) (cond ( (= x 70.0) (/ 19.0 4.0) ) ( (= x 130.0) (/ 19.0 3.0) ) ( (= x 132.0) (/ 19.0 2.0) ) ( (= x 150.0) 19.0 ) ( t x ))) '(70.0 132.0 70.0 132.0 70.0 70.0 150.0 70.0 150.0 70.0 70.0 70.0 70.0 130.0 70.0 150.0 70.0 130.0 70.0 70.0 150.0 70.0 70.0 132.0 70.0 132.0 70.0 132.0))
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 3 of 13
avinash00002002
Hi!
Thanks, for reply.
If my list is minimum 1 no. to N nos. of elements in the list. then....
Message 4 of 13
marko_ribar
@avinash00002002 wrote:
Hi!
Thanks, for reply.
I don't understand...
Please, explain better... Give examples of possible situations and desired resulting outcomes...
Message 5 of 13
avinash00002002
Hi!
I said my list is N nos. of list
1.    if my list elements is only one member like... (51) then the value of other list is 7.0
2.    if my list elements are two members like... (51 60) then the value of other list is 7.0 & 5.0
3.   if my list elements are more than two nos. like... (25, 30, 40, 45, 51, 55, 57, 60, 80, 95, 100) etc..
below calculation for all above lists.
Now it calculate the nos. of elements present in the list. say 11 nos. as per 3rd no.
it will divide ( 19 / nos. of elements ) = 1.72
LIST EXAMPLES:
(57 56 97 97 56 57 97 97 56 57 97 97 56 97 56 97 56 97 56 105 97 56 97 56)
(64, 64, 51, 36, 36, 36)
(115 65 115 65 115 65 65 120 120 94 65 120 65 120 65 120 65 65 105 65 65 65 103 115)
ETC..
Message 6 of 13
marko_ribar
Hi!
LIST EXAMPLES:
ETC..
Still you haven't explained well... I am seeking for examples showing both reference lists and resulting lists - outcomes... What is N and what is N nos - (we need to see what routine should do - not just reference list examples - if you can't write it manually, then try on some simple examples with only 4-5 elements and post them both separately - each example with both lists...)
Message 7 of 13
avinash00002002
LIST EXAMPLES:
LIST-->  (57 56 97 97 56 57 97 97 56 57 97 97 56 97 56 97 56 97 56 105 97 56 97 56)
STEPS: REMOVE DUPLICATES FROM ABOVE LIST and ascending
 = (56 57 97 105)
SO, TOTAL 4 ELEMENT VALUE
SO, 19/4.0
= 4.75
[ AT THE NEW LIST (57 56 97 105)
from above list for First Element = 4.75 x 1 == 4.75 (where 1 = element position)
for 2nd element 4.75 X 2 = 9.5 (where 2 = element position)
for 3rd element 4.75 X 3 = 14.25 (where 3 = element position)
for 4rd element 4.75 X 4 = 19 (where 4 = element position) ]
above calculation is after removing duplicates 4 elements are remaining, so we have divide 19 to the 4
if we have 12 element after removing duplicates then we have to divide 19 to the 12.
the ultimate results is: (9.5 4.75 14.25 14.25 4.75 9.5 14.25 14.25 4.75 9.5 14.25 14.25 4.75 14.25 4.75 14.25 4.75 14.25 4.75 19 14.25 4.75 14.25 4.75)
now we see second list
 list = (64, 64, 51, 36, 36, 36)
after removing duplicates  the list is (36 51 64)
so, we have to divide 19 to the 3 nos.
1. 6.3 --> for 36
2. 12.3 --> for 51
3. 19 --> for 64
result= (6.3 6.3 12.3 6.3 6.3 6.3)
3rd example
list = (115 65 115 65 115 65 65 120 120 94 65 120 65 120 65 120 65 65 105 65 65 65 103 115)
after removing duplicate = (65 94 103 105 115 120) = total 6 element.
so, we have to divide 19/6.0 = 3.16
1. 3.16 (= 3.16)
2. 6.32 (= 3.16 *2)
3. 9.48 (= 3.16 *3)
4. 12.64 (= 3.16 * 4)
5. 15.8 (= 3.16 * 5)
6. 18.96 (= 3.16 *6)
final result is
= (15.8 3.16 15.8 3.16 15.8 3.16 3.16 19 19 6.32 3.16 19 3.16 19 3.16 19 3.16 3.16 105 3.16 3.16 3.16 9.48 15.8)
Message 8 of 13
marko_ribar
Sorry for delay, I haven't noticed you posted reply... My phone didn't beep...
(defun foo ( lst / unique l k )
  (defun unique ( l / a ll )
    (while (setq a (car l))
      (if (vl-some (function (lambda ( x ) (equal x a 1e-6))) (cdr l))
        (setq ll (cons a ll) l (vl-remove-if (function (lambda ( x ) (equal x a 1e-6))) (cdr l)))
        (setq ll (cons a ll) l (cdr l))
    (reverse ll)
  (setq l (vl-sort (unique lst) (function <)))
  (setq k (/ 19.0 (length l)))
  (mapcar (function (lambda ( x ) (* k (1+ (vl-position x l))))) lst)
Message 9 of 13
avinash00002002
Great work,
I have mentioned that if the number of element is only 1. then result is 7.0 --> (5) as a list
and the number of element is only 2. then result is 7.0 and 5.0 --> (7 5) as a list
any updating reqd.
Message 10 of 13
marko_ribar
    (reverse ll)
  (cond
    ( (= (length lst) 1)
      (list 5.0)
    ( (= (length lst) 2)
      (list 7.0 5.0)
    ( t
Message 11 of 13
avinash00002002
Thanks, That is ok.
I need After removing duplicate element in the list, if 1 then result list is (7.0)
and
after removing duplicate element in the list. if 2 then result list is (7.0 5.0)
Avinash
Message 12 of 13
marko_ribar
    (reverse ll)
  (cond
    ( (= (length l) 1)
      (mapcar (function (lambda ( x ) 7.0)) lst)
    ( (= (length l) 2)
      (mapcar (function (lambda ( x ) (if (= (vl-position x l) 0) 7.0 5.0))) lst)
    ( t
Message 13 of 13
marko_ribar
Although, given the logic you want with unique lists > 2, smaller numbers => smaller resulting numbers... I'd write function like this :
    (reverse ll)
  (cond
    ( (= (length l) 1)
      (mapcar (function (lambda ( x ) 5.0)) lst)
    ( (= (length l) 2)
      (mapcar (function (lambda ( x ) (if (= (vl-position x l) 0) 5.0 7.0))) lst)
    ( t
