Comparing two lists
Comparing two lists
thomas.schive
Message 1 of 11
Comparing two lists
thomas.schive
Hello!
I am trying to do something quite simple - it is just a problem of writing the correct LISP of doing so ...
I need 3 different lists:
List1 is a list that contains all layers in a drawing;
(defun LayersList ( / )
(vlax-for lay (vla-get-Layers
(vla-get-ActiveDocument (vlax-get-acad-object)))
(setq List1 (cons (vla-get-Name lay) List1))))
I think this code is okay as it creates list1 consisting of the layers in the drawing.
Another list (list2) is a comparison list I create and define myself - for now let's say that list2 is put through
(setq list2 '("1" "2" "3" "A" "B" "C"))
Finally, I would like to compare the list1 with the list2 and give me the values (layer names) that do comply and the ones that don't comply. The values that don't comply I would like to constitute the third list "list3". I have tried with "member", "mapcar" and a few others without succeeding so far...
Any ways of writing this code?
Thanks!
Replies (10)
Message 2 of 11
ВeekeeCZ
Don't understand.
Give us imaginary examples of lst1, lst2 and desired outcome of lst3
lst3 is a result of comparison based on what? (hopefully, I could see that from given examples)
Message 3 of 11
thomas.schive
Okay, so let's say that I have in my DWG the current layers with layer names "0" "1" "2" "3" "A" "B" and "C".
My first list "list1" will then be the layer names listed as above: ("0" "1" "2" "3" "A" "B" "C").
What I want to is to find the layer names in my drawing (list1) that does not exist in my reference list (list2). The reference list "list2" is defined, as an example: '("0" "1" "2" "A" "B"). Call it the layer names that should be in the drawing. The ones that differ, in this case "3" and "C" are the layers that are not named correctly according to list2.
I want the ones that differ, "3" and "C" in this case, to be written into a list "list3" that is printed to the user to inform the user which layers are not named correctly according to the reference list "list2".
Message 4 of 11
ВeekeeCZ
Like this?
(setq lst1 '("0" "1" "2" "3" "A" "B" "C"))
(setq lst2 '("0" "1" "2" "A" "B"))
(setq lst3 (vl-remove-if '(lambda (x) (vl-position x lst2)) lst1))
>> ("3" "C")
Message 5 of 11
hak_vz
(setq list1 '("0" "1" "2" "3" "A" "B" "C") list2 '("0" "1" "2" "A" "B"))
(foreach el list1
(if (not (member el list2))
       (setq list3 (cons el list3)))
Miljenko Hatlak
Message 6 of 11
thomas.schive
Could not get this one to work, but the answer below with the foreach seems to provide the desired results.
Thanks to both!
Message 7 of 11
ВeekeeCZ
That's unfortunate.
You might need (vl-load-com) loaded. Then try
(vl-remove-if '(lambda (x) (vl-position x '("0" "1" "2" "A" "B"))) '("0" "1" "2" "3" "A" "B" "C"))
Foreach is good to know but mastering lists with such functions is essential! That's what LISP is all about.
Good luck!
Message 8 of 11
Kent1Cooper
Depending on what you intend to do with that information, it may be that the built-in >CAD Standards< features can handle it for you.
Kent Cooper, AIA
Message 9 of 11
thomas.schive
Hello again!
I was wondering - relating to this topic, whether the following code:
(defun Layerlist ( / )
Could be changed into ONLY listing non-xref layers in List1?
Thanks for your help, very much appreciated!
Message 10 of 11
ВeekeeCZ
Just test the layer name if it includes *|*. Pretty much the same thing as you used HERE
Message 11 of 11
hak_vz
See this post  and try to update your code.
Miljenko Hatlak
