Code doesn't work - AutoLISP
vinju
vinju
Hello everyone,
I've been trying to write a script that accomplishes the following:
- Let me select a viewport in a layout
- Get the rotation angle of the UCS in relation to the WCS using VIEWTWIST
- Select a specific dynamic block that has a parameter called "Winkel1" (German for: Angle1)
- Apply the number that I got by running VIEWTWIST to that parameter.
Here's the code:
(defun c:autonord()
(setq vp (car (entsel "Select the Viewport: ")))
(setvar "viewport" vp)
(setq angle (getvar "VIEWTWIST"))
(if (< angle 0) (setq angle (+ angle 360)))
(setq blk (car (entsel "Select the dynamic block: ")))
(if (member "Winkel1" (vl-block-dyn-propnames blk))
(command "._ddp" blk "Winkel1" angle "")
(princ "Angle value is: " angle)
(princ)
And this is the error I've been getting when I run the script and select a viewport:
Error: Settings for AutoCAD variable rejected: "viewport" <objektname: 23b0decadd0>
It would be awesome if any of you could help me with this problem!
I am using ACAD 2022.
Thanks so much in advance!
ВeekeeCZ
Try and see. If it fails and you to fix it, post a test dwg.
(vl-load-com)
(defun c:autonord ( / vp ang blk)
  (princ "\nSelect source viewport: ")
  (setq vp (ssget "_+.:E:S" '((0 . "VIEWPORT"))))
  (command "_.mspace")
  (setvar 'cvport (cdr (assoc 69 (entget (ssname vp 0)))))
  (setq ang (getvar "VIEWTWIST"))
  (command "_.pspace")
  (setpropertyvalue blk "AcDbDynBlockPropertyWinkel1" ang)
  (princ (strcat "Angle value is: " (angtos ang)))
  (princ)
ВeekeeCZ
@vinju wrote:
Hello everyone,
Here's the code:
(defun c:autonord()
(setq vp (car (entsel "Select the Viewport: "))) ; this is tricky, could be used only when the VP is the  "rectangle" type.
(setvar "viewport" vp) ; there is no system variable of that name
(setq angle (getvar "VIEWTWIST")) ; you'll get that only when the particular VP is active!
(if (< angle 0) (setq angle (+ angle 360))) ; all the system angles are in radians.
(if (member "Winkel1" (vl-block-dyn-propnames blk))  ; possibly some custom function... you did not share its definition
(command "._ddp" blk "Winkel1" angle "") ;; again, some custom command. don't know it.
(princ "Angle value is: " angle)  ; angle is an actual function name, you cannot use this name as a variable! also , princ does not work like that. Princ print only 1 string. you have 2 items and angle is not a string.
(princ)
vinju
Hey BeekeeCZ,
thanks for taking the time to help me.
Sadly, the code still didn't work. But it plotted a error-message I haven't encountered yet:
Error: Incorrect argument type: FILE "344.83"
I have added a test drawing to this response. The dynamic block is the one with the north arrow.
Maybe you can give it another try 🙂
Thanks so much!
ВeekeeCZ
Ok, updated.
vinju
Awesome! It works! - Thank you so much 😄
